#16 |
seriously??
I plugged the wastegate and it boosted to 10 before I decided not to go any higher ... like I said in my original post.
#17 |
Well it's only supposed to hit 7.5PSI stock, what did you expect to happen?
The confusion here lies in the simplicity of the answer.
#18 |
with an open exhaust I expected it to boost creep a little higher than 7, with the ported wastegate I expected that to control that condition. I didn't expect 5-6 psi with a open exhaust.
I was looking for confirmation that it was in fact the wastegate actuator (spring and diaphram part) and would replacing it OR getting a boost controller be the best option, and then hopefully someone would offer a spare actuator or direct me to another option.. its all good, I have... a plan... I have to replace one of the exhaust gaskets anyway because of a big leak so when I take it all apart i'll give it a good look over and i might have a spare actuator by then...
#19 | |
I say go with a boost controller.
#20 |
yeah me too
#21 |
Rep Power: 22 ![]() |
He has a boost controller, it isn't as effective as he thought however......or its broken.
#22 |
crash auto?fix auto
Simple fix.
Remove all that stuff, install a large 62-1, tail 44 wastegate with 15lb spring. lol ___________ Bust seriously - If the boost controller is hooked into the system, are you sure its plumbed correctly? Are any of the lines leaking? |
#23 | |
Rep Power: 21 ![]() |
well, how much are springs? Where can you buy them? Wouldn't it be smart to just replace it than risk it?
#24 |
lol, yeah, that would be a great solution!
#25 |
A 62-1 on a 6 port turbo? That would be fun for a little while at least.
#26 | |
What kind of boost controller is Paul running?
#27 |
I believe it is an old school HKS. I don't know what model for sure. It looks to be the same generation as his F-CON though.
#28 |
the boost controller i bought is broke, doesn't work...
and phoenix, the stock spring is not replaceable
#29 | |
Sad, I would have loved to have an old school HKS BC
#30 | |
lol. I never had to replace/fix my wastegate so thanks for the info.
