| Tires,Wheels,Suspension,Brakes Info about Tires, Wheels, Suspensions, Brakes, etc. |
IT'S ALIVE!
I had two issues with 16" wheels: tire selection and suspension clearance. The last time I checked there weren't many options for wide 16" wheels. 245/45R16 was being phased out and 225/50R16 was the most common to run on an 8" wide wheel. My issue with the suspension was the inside rim of the wheel wanted to inhabit the same location as the locking collars on the coilover assembly. I had to use those aftermarket camber bolts to rotate the hub away from the suspension and then dialed the camber back with the coilover top hats.
| Tags |
| 114.3, offset, roen, spacer, wheel |
