#241 | |
Professional Stick Poker
#242 |
Rep Power: 10 ![]() |
I have no idea what you're talking about
#243 |
Yeah riiight! My bullshit-o-meter just snapped off the needle.
#244 |
Butt seriously, I haven't touched any of my rotaries for about a year now! But they're all broken right now
#245 |
... and done with the midpipe ... finally. I got the welds smoothed out, primered and painted. Bolted into final installed position. Now on to creating a really screwy muffler that fits in front of the rear axle, in the little bit of space that I have. Then I have to go over the axle with the pipe and connect it to the rear section and muffler I already did. The things we won't go through to ensure a relatively free flowing exhaust that has a chance of surviving backfires.
![]() midpipe painted by Kevin Frank, on Flickr midpipe final install by Kevin Frank, on Flickr
#246 |
Finally got the middle muffler cut, bent, and tacked with the TIG. The thin wall perforated pipe is a stone cold b***** to try and TIG. Ugly, but it's going to get wrapped in steel wool and closed up in a case so ... meh.
middle muffler (guts) by Kevin Frank, on Flickrin other news, The latest snow has mostly melted off and I broke out the FC today. Zipped it around for a bit to get everything lubed and let the battery come back to a full charge. It's nice to be driving something fun for a change.
#247 | |
Rep Power: 17 ![]() |
Woohooo!
#248 |
Rep Power: 20 ![]() |
That's freaking cool man! Kudos to you for making your own muffler! I guess you have no choice but to.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#249 | |
#250 | ||
#251 |
New tool to get the outer case bent for the muffler from hell. This is going to be one of the most expensive little mufflers in history I'm afraid.
sheet metal brake by Kevin Frank, on FlickrGetting the core wrap around all the bends has been a painful experience. My fingers have been poked so many times with wire from the screen and wool that they will be hurting for a week. muffler wrap 1 by Kevin Frank, on Flickr
#252 | |
I'll Poke you So many Times....
#253 |
such a tease you are.
#254 |
Middle muffler is fabricated, packing in, and tacked together.
middle muffler 1 by Kevin Frank, on Flickr middle muffler 2 by Kevin Frank, on Flickr middle muffler 3 by Kevin Frank, on Flickr middle muffler 4 by Kevin Frank, on Flickr
#255 |
Muffler is welded and cleaned up ready to install. My TIG welding skills are even worse than my MIG skills. It's going to take a lot of practice to get the hang of TIG.
Pre-cleanup .... middle muffler - welded (pre-clean up) 1 by Kevin Frank, on Flickr middle muffler - welded (pre-clean up) 2 by Kevin Frank, on FlickrQuite ugly, but it's together in spite of myself. Had to grind them off a few times and redo welds a couple of times. Post-Cleanup ... middle muffler - welded (post -clean up) 1 by Kevin Frank, on Flickr middle muffler - welded (post -clean up) 2 by Kevin Frank, on FlickrGround the welds down a bit to smooth them out some, but mainly looking for pin holes. Only had a couple that I could find. I'm sure more will show up once it's running. Folding would be better, however the oddball shape precluded that.
