Hey Zach, quick note.
For the sense wire, you could technically run a wire from the B+ on the alternator to the pin, but the voltage at that pin is used as reference for regulating... If say, your battery is in the back, the voltage read at the battery will be less that at the B+ "output" of the alternator... This could make the alternator regulate the voltage .1 or .2 lower than it normally would in stock config, or what you would prefer. so, its good practice to have that sense wire be at least a little bit down the line from the alternator... If stock its hooked up at the fuse box, its probably best to hook it up there.
#2 | |
Rep Power: 20 ![]() |
But yes, I have done that temporarily in the past.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 Last edited by FC Zach; 03-11-2017 at 01:18 AM. |
