#16 | ||||
Rep Power: 10 ![]() |
That's where it stops being easy.... Obviously a ridiculous amount of fab Why? It would be soooooooooooo much easier to remove all the emmissions related crap from the Miata harness, honestly it unplugs, build a new engine harness and adapt the power to feed it. Quote:
Nope nope nope nope nope.... been there, done that, no fucking thank you. Pete... we put an S5 n/a into a Miata in a week at the shop. Used the stock ECU. Harderst part is going the be mounting the engine. If you're serious about the project.... text me. The next big build I do for myself is going to be a 400+ rwhp 13B-RE Exocet
-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- Last edited by TitaniumTT; 09-07-2016 at 09:01 AM. |
#17 |
Hi Titanium TT,
Yeah it wasn't easy. Plus all the miata running gear just looked too puny to handle the stock power of the FD. So all the FD running gear had to stay. With that, all the FD suspension went in as well. FD cross member...all the front suspension points still on the cut out chassis mated to the front miata firewall. The rear was hard. Removed the miata fuel tank because thats where the rear suspension hard points and diff/prop shaft wanted to sit. If I can find my old hard drive I'll post pics. The stock miata tach didn't go past 7000rpm. The speedo only went to 220 I think. The Apexi ECU was on the donor car so it went in with all the wiring. Had a problem making the wipers work. Lol. Looking for pics. |
#18 |
#19 |
Rear trailing arms.jpg Firewall out.jpg RX7 Miata front end 2.jpg Rx7'miata front end.jpg I apologize if there isn't any order to the way I've installed the photos. |
#20 |
Airbag.jpg Engine problem.jpg My biggest problem was with the engine. I learned how to take it apart and rebuild it. Had to do it twice. |
#21 |
Rep Power: 20 ![]() |
Do you have any more info on how you did the hinges for the airbag compartment? I removed my airbag and I've been wanting to put hinges on the lid for a while but couldn't think of how to do it.
#22 |
Speedjunkie.
The hinges were cheap cabinet hinges from a hardware store. I used a pair of RC car shocks/springs I had laying around. I then made my own latch. I even had a jeweler friend make me a tiny mazda wing badge out of white gold with a long straight tiny rod behind it. Hooked that up to the latch mechanism and push it to spring open and shut the airbag cover to lock. As for the cover itself. Mine is made from fiberglass and balsa wood and lots of epoxy slurry sanded to the shape I liked. Made it fatter using balsa wood to save weight. |
#23 |
Speedjunkie. The cabinet hinges were the type that pull out and extend a bit. I hope that helps.
#24 |
Interesting, thanks! I bought several different types of cabinet hinges but haven't found any that would work yet. I'm using the outer cover from the airbag so it looks original. I was afraid it would fly off while driving but so far it has stayed in place even during aggressive driving. I get into that compartment more often than I thought I would so it would be nice if the cover hinged open.
#25 |
Here's what I been doing. The CF doors are getting fitted with the hardware. Body almost ready for paint.
IMG_1344.jpg IMG_1345.jpg IMG_1346.JPG IMG_1347.jpg IMG_1348.jpg |
#26 |
#27 |
That's damn cool!
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#28 |
IT'S ALIVE!
Indeed, very cool! I wish I could have carbon fiber (or even fiberglass) doors for my FC.
#29 | |
Love the Miata.
#30 |
Thanks for the interest in my carbon fiber doors. Wait'll you see the hood and bumpers.
Meanwhile this is how the rest of the car looks: IMG_1354.JPG IMG_1355.jpg IMG_1356.JPG IMG_1357.JPG |
