| 2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
GTA Bryson City
S4 NA Parts (Asheville NC)
Selling off all of my S4 NA stuff. Prices are all plus shipping, and negotiable, especially for multiple items purchased together. I have a lot more than this, but haven't gotten the rest cleaned up and inventoried. If there's anything S4 NA that you need ask.
Pulley Set 40 Torrington Bearings/Plate 10 CAS Drive Gear 5 Dowell Pins (4) 10 Oil Pump Gear 5 Alternator mount 10 OMP and gear 30 Tension Bolts (17) 50 Stat gear 30 CAS 40 Front Cover 40 E-shaft 50 LIM 75 ACV and sensors 30 PCV 10 Power Steering Pump 80 Power Steering/AC Bracket 40 Housings 150 Clutch Fan 50 Oil Cooler 60 Oil Cooler Lines 50 Photos of all items in album at link. https://goo.gl/photos/6XMeyHGwe6xw998u6 PM, E-Mail, Text or Call dmaudlin@gmail.com 828-222-oh for nein six |
GTA Bryson City
Adding new items below (if also listed above, then I have two)
On the housings: This set came out of a motor I bought as part of a lot. I was told it ran when pulled, but made low compression, and blew a coolant passage. They both housings have some scoring around them. There's nothing too deep to resurface or rechrome, but I probably wouldn't run them as-is. Surprisingly there's no edge flaking at all, nor spark plug hole cracking, heat discoloration, or any other nasties than the light scoring/chatter. On the Irons: The worst step wear read at 0.10mm or .004", and is twice as deep as the next worst on both plates. All should be able to be lapped smooth without going past the nitrating. Stock ports. Photos of new items added to same linked album. https://goo.gl/photos/6XMeyHGwe6xw998u6 S4 LIM w/ ACV, OMP Inj 75 A/C Compressor 50 Pulleys 20 Water Pump Housing 40 Water Temp Sensor 25 Metal Fill Neck 30 Water Pump (zero play in any direction) 30 Pair motor mounts, good condition 35 or 20 each Vacuum Rack 20 Primary Fuel Rail 30 460cc Low Imp Injectors x2 30 Auxiliary Port Actuator (1) 10 Oil Cooler Lines 50 Front Counterweight S4 NA 20 Thrust Plate 5 Stationary Gear 30 S4 NA Oil Pump 40 E-Shaft Pulley Drive Snout 10 Oil Fill Neck 5 Oil Filter Pedestal 10 Aux Port Sleeves 20 Oil Pump Chain 10 Oil Pressure Regulator 10 Engine hangers (Both) 10 Oil Pressure Sensor 20 Oil Pan (misc fasteners separate)25 Oil Level Sensor 10 Front and Rear Iron 100 - Center lost a coolant passage, but if you want it for some reason I'd sell it. |
