Old 05-03-2016, 02:18 PM   #11
FC Zach
FC Zach's Avatar
Hey Zac, looks great man! Digging it it. I would like to see where you ended up with the timing and I definitely want to know what she ended up making for power on the dyno when all is said and done.
Thanks, I'm pretty stoked to see the results too! Not sure when Ludwig comes to town again but when he's here he can make changes if needed while on the dyno
Your Ambient Air Intake system - Love it and especially the use of that profile gauge to get started.... going to need to go buy a bigger one of those. When you're done with the sheet metal work what you can do is take some silicone vac line and slit it open and apply to the surface that's going to be nexto to the paint... protection and all
Yeah, I would like to find a larger gauge. I have the typical 6" gauge, which works but I had to do about four or more overlapping segments to help keep the shape. I like the vac hose idea. I was thinking about that yesterday but was worried the thickness of the hose would be an issue.
The only thing that I see may be an issue is going to be the air feed from the brake duct opening. I don't think it will force much if any air from the brake duct to the air filter location. It might even create a small vacuum. I would suggest, as Ted has, to take a peek at Pegasus racing and try to find some ducts that you could split off of to feed both the brakes and the air filter.
I'm doing something very similar with my FC right now. Taking two of their dual outlet ducts and using one to cool the oil coolers, and the other is going to the brakes.
I'm glad you mentioned this as it is a worry of mine and I wanted someone else to mention it before planting it in anyone's head at first. To test for any difference I'll monitor IATs with and without the back opening of the OE brake duct blocked off. If I have a difference, which I'm sure there will be I may look into the Pegasus duct inlet Ted mentioned. . We'll see.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
