Waffles - hmmm good
It could be a clutch or throw out bearing.
#2 | |
Can't.Make.Up.My.Mind.
Indeed.
I guess thats getting added to the list to then. So even though its happening when I'm off the clutch it could still be either?
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
#3 | |
Their stuff is crap... -Ted |
Well that would have been nice to know. What's to bad about their stuff? Seems like it would be kinda hard to mess up a poly mount.
#5 | |
Remember the old adage? If it's too good to be true (i.e. cheap), then it is... The stock type mount (this goes for the engine and trans mounts), are two studs attached to two plates of metal with a rubber sandwich in between them. This allow both compression and pull forces to be absorbed by the mount itself. All these cheap-ass vendors who sell this crap built these mounts that can only handle compressor forces; they do not isolate the pull forces, as you're asking against the bolt / fastener. What does this all mean? You get increased vibration through this cheap-ass mount... It could possibly damage something else, as now your mount does not isolate tension forces... You get an inferior mount, because they are too cheap to build a proper mount... Anyone can get a block of (insert fav...rubber, polyurethane, nylon, UHMW plastic, aluminum, hockey puck) and drill a hole in it and slap on a nut and bolt... -Ted |
#6 | |
Rep Power: 20 ![]() |
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
