			 business as usual
				Rep Power: 0 ![]()  |
				Quick voltage question for all of you.
			Before and after warm up (drive-time), what does your voltmeter on your gauge cluster read?
			Mine goes from 12 to 13.1, that is if .1 V is even possible.
	Bitch  |
				Rep Power: 18 ![]()  |
			should be 14.7
			your alt may be dying, lose connection, belt slipping, etc
			Or corroded cables...
		#4 | |
			My S4 alternator doesn't put out anything until I rev it up once, then starts putting out like normal, kinda weird.
		#5 | ||||
				Rep Power: 21 ![]()  |
 +1 Quote:
 Learned most of that from RETed.
		#6 | |
			Well hopefully not as its freshly rebuilt
		#7 | |
			so was mine, twice.  The wire kept killing it.  It's been at least a month already and no problems after bypassing the stock output wire.
			mine always were in the 14.4 ish range.
	For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook  |
		#9 |
		#10 |
			 business as usual
			It could just be the battery, may need a recharge.
			I made a thread before about my batteries keep on dying, which turned out to be a faulty alt. I didn't replace that battery so that maybe it. The voltage been this way since I replaced a new alt.
	Bitch  |
		#11 | |
			go to Kragen's and have them test the battery.
