Old 07-09-2008, 10:10 PM   #1
Eatmyclutch
business as usual
Eatmyclutch's Avatar
Eatmyclutch is an unknown quantity at this point
Quick voltage question for all of you.
Before and after warm up (drive-time), what does your voltmeter on your gauge cluster read?
Mine goes from 12 to 13.1, that is if .1 V is even possible.
Bitch
Eatmyclutch is offline   Reply With Quote
Old 07-09-2008, 10:24 PM   #2
josh18_2k
should be 14.7
your alt may be dying, lose connection, belt slipping, etc
Old 07-10-2008, 12:04 AM   #3
Kentetsu
Kentetsu's Avatar
Or corroded cables...
Old 07-10-2008, 12:06 AM   #4
My S4 alternator doesn't put out anything until I rev it up once, then starts putting out like normal, kinda weird.
Old 07-10-2008, 12:59 AM   #5
ALternator comes to mind first. I had a weird one: The output cable was bad and kept killing the voltage regulator.
Originally Posted by josh18_2k View Post
should be 14.7
+1
+1
I did that for a few months. Expect your alt to crap out soon. Worse case scenario: You blow your electrical system from an overload. When you rev and it adjusts the voltage it may mean the voltage regulator is dying/faulty. It COULD ZAP your electrical system just as easy as it undercharges it. Keep an eye out and test the voltage at the B-terminal.
Learned most of that from RETed.
Old 07-10-2008, 01:08 AM   #6
Well hopefully not as its freshly rebuilt
Old 07-10-2008, 01:17 AM   #7
so was mine, twice. The wire kept killing it. It's been at least a month already and no problems after bypassing the stock output wire.
Old 07-10-2008, 08:12 AM   #8
mine always were in the 14.4 ish range.
Old 07-10-2008, 11:15 AM   #9
Jeff20B
Jeff20B's Avatar
Mine did that when the T-shaped connector fell out the back. Plugged it back in and worked like stock again.
Old 07-10-2008, 07:46 PM   #10
Eatmyclutch
business as usual
It could just be the battery, may need a recharge.
I made a thread before about my batteries keep on dying, which turned out to be a faulty alt. I didn't replace that battery so that maybe it.
The voltage been this way since I replaced a new alt.
Bitch
Old 07-10-2008, 09:36 PM   #11
go to Kragen's and have them test the battery.
