| 3rd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
fuel system/alcohol kit/EBC/greddy elbow/works bell/rear counterweight/99+ ECU/ETC.
PM me if interested...
Fuel system - KG rails, new aeromotive FPR, new autometer 3312 gauge, 2x ID725 injectors with hats, all SS lines and fittings pictured - $500 99+ ECU - $40 Works bell rapfix 2 hub and hub lock with key - $325 Apexi auto timer with FC harness - $50 HKS EVC EZ - $120 Cooling mist alcohol kit – comes with controller, pump, tank, new lines, new nozzle, new misc other fittings - $160 New? Greddy elbow w/ alcohol injector nozzle bung welded on - $100 aftermarket waterpump outlet - $25 stock waterpump outlet - $20 alternator with pulley and bracket - $80 New connectors for crank sensors, tps, 2 new square injectors pigtails - $15 New jegs through panel connectors w/ hole saw bit - $15 Stock flywheel - low miles - $40 Rear counterweight with mounting bolts - $100 |
