Waffles - hmmm good
I think the SA tranny will get the shifter closer to where you need it. Or maybe you can
futz with the tail shaft to shorten it. Either way you will need a custom driveshaft anyway.
#2 | |
Professional Stick Poker
The SA trans will only move the shifter about 2 to 2.5 inches, an RX8 trans would move it 3.5 inches. Either way it is far short of the 8.5 inches that it probably needs to move to keep the shifter in the stock position. I am a little worried on tail shaft length though as the drive shaft is already pretty short. If I get the driveshaft too short I'm likely to have vibration and U joint binding problems.
