Waffles - hmmm good
If all you did was run for short spurts, the battery never got recharged 100%. Recharge that
battery and you are probably good to go.
1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00 Last edited by t_g_farrell; 04-14-2015 at 01:43 PM. |
Rep Power: 20 ![]() |
The battery appeared to be bad according to my trickle charger so I bought another. The car cranked better but still no spark. . Eventually the starter went south and luckily for me the local Advance had one in stock.
We tried adjusting the gap between the trigger wheel and sensor, tested voltage to coils, and even attached an OEM CAS to test for spark which gave the same results. Everything but the ignition appears to function properly. What makes this a mystery is that nothing has changed since Sunday afternoon and now no spark.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
