		#16 | |
				Rep Power: 20 ![]()  |
	The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group  |
		#17 |
			I need Front diff mount thread and pitch info.
		#18 |
				Rep Power: 19 ![]()  |
			Was 1.25 not correct? If not, you're probably right assuming its 1.5. I would pull one off tomorrow and tell you but I've got my sister's wedding to attend.. if you dont find the answer by sunday night I'll find out for you...
		#19 |
			I don't know off the top of my head.  I tried using an M8 by 1.25 (I think, may have been an M10) but it was too small.  I ended up finding the missing nuts caught in the mount itself.  Talk about lucky.  Now I'm going to go find a shop that can get this taken care of today... hopefully.  I don't feel like dropping my subframe at all...
		#20 |
				Rep Power: 0 ![]()  |
			christ this was a big help to me as a beginner haha. THANKS!
		#21 |
			 rotor's are in my blood
			I need to know what size the nuts going on the lateral links into the rear subframe.
		#22 |
			 ORD - Old Rotary Dude
				Rep Power: 18 ![]()  |
			Anyone know the bolt size & pitch of the two on the front cover of a TII, underneath the CAS? Looks like a 12mm but I don't have any bolts to try in any pitch.
	JTB  |
		#23 |
			Bolts for the front oil cover?
	Yes, they are all 12mm *hex head*. 5 or 6 of them in total in differing lengths? 12mm hex head are 8mm *thread diameter*. So it's 8mm x (pitch). Typically 8mm thread pitch is 1.25, but it could be 1.00 or more rare 0.75. -Ted  |
		#24 |
			Thanks a bunch for the reply, Ted. However, that's not the bolts I am looking for. On the driver's side of the front cover, directly underneath the CAS, there are two bolt holes. These are the ones I am looking for. I believe the two holes were for an A/C mount or P/S mount.
	These are two big bolts, approximately 12mm bolt size, not head size. JTB  |
		#25 |
			Ah, the ones off the bracket that normally holds the A/C and (optional) power steering pump?
	-Ted  |
		#26 |
		#27 |
			Yeah, if you are asking about the two "missing" fasteners that's in the aluminum part of the bracket - right in the middle of your pic - then those were originally studs.
	You still want the thread pitch and diameter of the studs? -Ted  |
		#28 |
			Yes, I would still like to know the diameter (size) and pitch of the studs?
		#29 |
			The "outside" spec is 10mm x 1.25.
	I hope the inside thread is the same... This is the typical 10mm pitch. Only the exhaust studs are 10mm x 1.50. The oil metering "valves" are threaded 10mm x 1.00. -Ted  |
		#30 |
			FYI: Bolts for body in/around engine bay are 6M-1.0mm Length unknown, but I have found 12mm full and partial threaded that would suffice. These include the front mounting location of the bumper skin, fenders, etc. I am assuming the lower threads are identical but haven't checked.
