Show your rotary car build up. Show off your Rotary Car build! |
#76 | |
Rep Power: 13 ![]() |
#77 |
Rep Power: 21 ![]() |
check out the trans diff FAQ
Mazda Miata Gearbox 1st: 3.136 2nd: 1.888 3rd: 1.330 4th: 1.00 5th: 0.814
#78 | ||
12A Engine Swap (Cont.)
Mazda Rx-7 87-88 13B 6PI (Type M) Gearbox 1st: 3.475 2nd: 2.002 3rd: 1.366 4th: 1.00 5th: 0.697 and my original GSL-SE transmission... Mazda Rx-7 84-85 13B (Type M) Gearbox 1st: 3.622 2nd: 2.186 3rd: 1.419 4th: 1.00 5th: 0.807 I agree the Miata gearbox seems like a good bet. Lower 1st and 2nd gears should be better in the mountains and the shorter split between 2nd and 3rd should improve overall driveability. The .814 overdrive should even allow for some acceleration in 5th... hard to say if it could improve overall top speed though. In the past when I've tested top speeds on various cars, the rev-limit in 4th gear is the maximum gear-limited top speed unless you have enough power to overcome all that wind resistance in an overdrive gear. (Or just happen to be driving down a really long steep hill) Reading up about modifying the miata input shaft got me thinking though... I saw this pic on Mazdatrix and I was wondering if it was possible to use an RX7 input shaft on a miata gearset? That would simplify things a lot. ![]() However, after searching about it, it seems that it has been tried with no success. Quote:
#79 |
the longer first is better all around. short 1st is useless
#80 |
So I decided to give up on the fb project. I traded it for a Corrado VR6 that also has upgrades to its brakes and suspension. I was too impressed after driving it to say no.
But by no means am I giving up rotaries themselves. If I coulda kept both I would. I'll still be attending rotary meets and helping friends with their RX7's, so I'll be involved in their scene indefinately no worries. |
#81 | |
Rep Power: 17 ![]() |
#82 | |
Professional Stick Poker
#83 |
well the corrado is a neat car. At least its not a G-Lader either!
#84 |
I'm back behind the wheel of a rotary again... albeit an unusual frankenstein build, but it will be fun!
![]() The GSL-SE is actually sold to a good friend of mine now who lives in my neighborhood. So I still see it all the time and occassionally go for a spin in it. Here's recent pics... ![]() ![]() Last edited by scarsofcarma; 02-21-2015 at 07:08 PM. Reason: adjusting image size |
#85 |
Rep Power: 20 ![]() |
Looks good! I like those wheels too.
Bookmarks |
Thread Tools | |
Display Modes | |
