Old 05-30-2008, 03:47 AM   #1
Rookie84
Rookie84 is on a distinguished road
What is the thickest wheel spacer that I can use?
I have a set of wheels that I'm considering but the offsets might be too high. So I was wondering what the max thickness of spacers can be before I have to replace the wheel studs with the longer ones, which is too much headache IMO. Also, I noticed our hub size is same as the Mitsubishi hub, so I'm assuming I can use hubcentric spacers made for Mistubishi's?
Thanks in advance.
Rookie84 is offline   Reply With Quote
Old 06-17-2008, 03:00 AM   #2
N3philum
Unreliable Like a Rotary
N3philum is on a distinguished road
you can get hubcentric spacers that bolt on. Kics is the company i like. they are a bit expensive but they are great quality. just make sure you get the 5x114.3 bolt on spacer.
as far as the little shim style spacer.. anything over 5mm i would say is junk.. if your going any bigger than that just replace the studs or get the bolt on type.
N3philum is offline   Reply With Quote
