#8 | |
Don Mega
For me I tested it only recently to ~1100deg C EGT on a T4 flanged set up that was prone to EATING gaskets, problem solved so far. ![]() This came about due to me doing research on alternative sealing methods (spent 2 months on it with various people around the world) and wanting to go away from the use of gaskets on normal bolted flanged turbos, but also eliminating leaks on V'bands... I have other systems that I will/am testing such as Nickle based wire in a groove machined into the turbo flange, but so far that system is not needed with the use of this product
