Old 06-11-2008, 09:20 PM   #1
DriftingFC
DriftingFC is on a distinguished road
low oil press problems at idle
Im runnin roughly 17-21 lbs of pressure at idle and I can get 60-70 @ 3K rpms. Its a fresh rebuild, so I dunno if that could be a problem. I am honestly thinkin that my front cover O ring mite have squeezed out. I cant rev to 6k cause its a fresh engine so I was hopin for some ideas from you all of a possible other culprit then the O ring.
Thanx.
DriftingFC is offline   Reply With Quote
Old 06-11-2008, 09:23 PM   #2
TehMonkay
Did you torque the oil pump down to spec and bend the lock washer up on the side of the nut?
Old 06-11-2008, 09:29 PM   #3
DriftingFC
Yup. It was my frist rebuild. (engine was actually in pieces when I got it) I spent 2 months reading, re reading and asking questions, checking all tolerances, clearances, the housings, the irons as the manual says to do. Even mocked up a junk engine that I had to make sure I did it right. Took it apart and did it again before I put this one together.
All torque specs were followed. This wasnt my frist engine I have ever rebuilt, just my forst rotary.lol
Old 06-11-2008, 09:54 PM   #4
15psi at idle is normal.
What were you expecting?
Old 06-12-2008, 07:19 AM   #5
I was going to say.....that is not low pressure. I get around 20-25 at idle (when warm) and 70+ depending on RPM (anything over like 2K rpm).
When Fero313's FC had low pressure, it was ZERO at idle, and would bleed a little when sustaining RPM's. Then you have a problem!
Old 06-12-2008, 10:14 AM   #6
Barry Bordes
Barry Bordes's Avatar
Mazda’s specification is 50psi @ 3000 rpm minimum on 3rd gens. I run a 1000-1100 rpm idle to float the bearings better.
Barry
GOD the Incomprehensible Obvious (www.frksj.org)
Barry Bordes is offline   Reply With Quote
Old 06-13-2008, 10:48 AM   #7
DriftingFC
Well damn then!!! Thx for the reassurance guys. only 1823 more miles till I can let her rip!!! lolz
