Old 05-21-2014, 08:26 AM   #1
theorie
VRR PSSH
theorie's Avatar
theorie is on a distinguished road
Recharged the A/C yesterday using my Harbor Freight compressed-air-powered vacuum pump and A/C Manifold Gauge set.
I still had several bottles of ES-12a left over from the last time I charged my silver RX-7's A/C (that must have been like 4 years ago) and I had good results with that stuff so I used it again.
The first thing I did was pull a vacuum on the system to check for leaks. I let it sit for over half an hour and found it held just fine (no leaks!) and then released the vacuum (since you're not supposed to charge with a vacuum when using ES-12a).
I used about a can & 1/2 (and they are 6oz cans) to charge the system. At idle, this gave me about 45psi on the low side and 175 on the high side. The high side seems a little low, but that's expected when using this stuff, as I understand.
Anyway it blows nice and cold now. Haven't done a temp test yet - just glad it's blowing cold air with FL summer heat coming...
1993 SSM, 20B (D449), SINGLE-TURBO, DIY-BUILD IN THE WORKS... |Build Thread|
1993 BB, 13B, SINGLE-TURBO, DAILY DRIVER |Build Thread|
MY FACEBOOK PROFILE // BLACK LABEL ENGINEERING // ADVANCED RACE TECH // IR PERFORMANCE // THE BOOST LAB //
[url=rotaryaddicts.com]
theorie is offline   Reply With Quote
