Old 02-28-2014, 11:09 PM   #11
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
OK. Plan 436. I ran out of letters a ways back and had to start numbering them.
To fix the problem of being at the end of my adjustment range (and still being .2 degrees off in caster side to side). I came up with putting an adjustment rail on top of my existing camber adjustment rail. This necessitated raising the mounting point and opening up some more room to the rear. I'm using stop bolts on both sides of the clamping rails so I hopefully get no movement from my adjusters when under load. This is in addition to the bolts that clamp it all together. I have been a little concerned to make doubly sure I get no movement once I get the @#$%^ thing adjusted to the correct spot.
The bottom cradle will also be able to move forward and back using a bolt and stop nuts on the bracket at the front of the lower rail. The clamping bolts on the lower rail will be slotted. It SHOULD fix my adjustability problems. I need to weld in a plate to close up the top of the mount with the upper hoop and put some gusseting across it so that the mount is rock steady.
Not the most elegant solution, but I will have full fine adjustability to dial it in, as well as the ability to make large adjustments when I decide to do something stupid. Such as playing with my wheelbase.
Me actually getting the car to DGRR is starting to look pretty iffy, since things are refusing to cooperate. Regardless of whether the little (insert Peter's favorite word here) gets there or not, I plan to be there this year.
plan 436 by GySgtFrank, on Flickr
GySgtFrank is offline
