Show your rotary car build up. Show off your Rotary Car build! |
#151 |
How does the Radium tank work, is there a pump in it, after it? or does it just fill up after the intake pumps and retain the pressure?
#152 | |
http://radiumauto.com/media/techarti...e-Tank-work-79 |
#153 |
But what if the 2 (or 3) pumps in the surge tank outflow the in tank pump? I know it would take a while for it to deplete especially with the fuel return going to the surge tank.
But what about in a scenario like the texas mile, not saying I want to do it, but could this potentially starve if you are flat out for a long period of time? |
#154 | |
#155 | |||||
Rep Power: 10 ![]() |
You know my rec ![]() Quote:
EDIT... after finding the flow chart and extrapolating the curve with my calculating eye, it looks like ~ 450/lph ![]()
#156 |
Ok cool, didn't think about the pressurized vs. no pressure difference. I have the hyperion baffle installed, so if my car ever runs and it doesn't work all that well I may make the switch.
#157 | |
![]() Have you even looked at the model I sent you? |
#158 | |
Of course I have!
#159 | |
So drilling and tapping the secondary rail is easy enough, however the Flex Fuel sensor will already be in the return line so I will have that temp. I need to know the DeltaT so I will get one of those AN to AN adapters with 1/8th NPT in the middle. I'll install that at the engine before the primary rail. I have the extra 1/8th NPT sensor I was planning on using for the Diff already, I'll just borrow that. looking forward to test this out... I like data. |
#160 | |
Very cool. I'm waiting on Aaron and Jayson @ FFE to come out with their new rails before I dive into redoing the fuel system and adding the fuel temp. I'm not going to get the DeltaT just the temp in the rails.
I would also like to add a pressure sender before the filter, pulling a log will let me know when it's starting to clog up. Quote:
Diff temp you say? Intrigued I am.... I may have to borrow this idea and put a sender in my tranny Indeed... I'm putting a PS2000 in my vert... I have so many inputs that I need to move the to a CAN EGT setup and I might even look into the CAN I/O Expander
#161 | |||
This is the fuel filter I am getting. I want a stainless element for E85, and dont want some BS 40 micron filter. This is one of the nicest filters (with the most filtration area) I can find with a 10 micron SS filter. http://www.foreinnovations.com/product_p/16-900.htm They give you the option to purchase mechanical pressure gauges for the inlet and outlet. I will be doing this. No need to use up inputs for something you can just check every once in a while (I'm aware there is the small possibility for it to clog quickly in rare instances, my fuel pressure protection will protect me from damage if this happens though). Does your ECU have the capability to set a warning for pressure drop across two pressure inputs? I could setup a math channel to monitor it and have it displayed on a race dash such as the AIM MXL (I really want the new MXL2 or color dash BTW ![]() Quote:
http://www.aemelectronics.com/Images...%2030-2012.pdf Quote:
I REALLY want to get a baseline for both because I plan on adding a cooler (or 2) but don't want to just add a cooler for the sake of adding a cooler. Need to get the data first to justify it. I suspect it will definitely be necessary for the trans though. |
#162 |
Rep Power: 15 ![]() |
I know my trans and diff temps :-).
Unfortunately no track data yet just street cruising. Max trans temp was 175 degrees F on a 800 mile drive in 62 degree F ambient day. Diff was about 180 degrees F on the sme day. Those hardlines look sexy. Last edited by RENESISFD; 02-06-2014 at 09:15 AM. |
#163 |
#164 |
^ Ninja edit above
:'( very funny John |
#165 |
Bookmarks |
Tags |
ducting, ducts, fd3s, jhnrx7, track |
Thread Tools | |
Display Modes | |
