Old 01-11-2014, 12:13 PM   #1
WankelsRevenge
WankelsRevenge's Avatar
Tracking down electrical gremlins
Recently I've been having some issues with my battery not wanting to hold a charge. I know part of this is due to the cold weather along with not driving my car regularly. However I jump started it one day and got it running, but the next day my battery was completely dead. One clue I do have is anytime my car has power but isn't running (I have a master kill switch on my batter which I've been using to completely kill the power to my car) my turn signal arrows in my gauge cluster are lit up. I have no idea what this may be a sign of but it started doing this right at the same time I started having electrical issues. Does anyone know what may cause this or what it's a sign of?
Summary of this thread:
Old 01-11-2014, 01:09 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
FC electrics?
Old 01-11-2014, 01:13 PM   #3
WankelsRevenge
Haha yeah. Gotta love 30 year old wiring/electronics.
Old 01-11-2014, 01:22 PM   #4
GySgtFrank
GySgtFrank's Avatar
I've had similar problems with dash stuff and traced it to the CPU needing re-soldered. From what I've read it's a common problem with the FC CPU. It could be so many things though that this is just a WAG.
Old 01-11-2014, 02:03 PM   #5
JL1RX7
Usually the alarm system will keep a slow draw on it. Plus some other random stuff to really make guess. I will pull the cables from the battery if I know I won't be driving it for a bit. Seems to make things play a little nicer. Sucks to reprogram the radio and the clock each time but oh well.
Old 01-11-2014, 02:08 PM   #6
WankelsRevenge
Well I dont have an alarm on mine so that isnt an issue at all. Really the only thing thats making me paranoid is why my blinker lights in my gauge cluster are staying on even if the cars not running, or without the key in the ignition for that matter. But like I said I have a master kill switch for my battery inside the interior so Ive just been killing all the power when Im not running the car and that seems to be working for now.
Old 01-11-2014, 02:21 PM   #7
JL1RX7
I would find the wiring diagram for that circuit and see what could be on. Sounds like a short that is doing it. Check all your grounds since the FC never had good ones from the jump.
Old 01-11-2014, 04:27 PM   #8
Electrical problems are always a PITA...
There is no way around it.
Cross your fingers you come across it sooner than later.
Basically, you need to understand the wiring diagrams (in the FSM).
Once you've got that under your belt, get a DMM that can do current draw, or Amps.
If you've got no clue where to start, I'd start under the hood...
Disconnect negative terminal from battery.
Measure current by switching DMM to current (i.e. Amps) and connect one probe to negative battery post and the other probe to the now disconnected negative battery terminal.
Normal current draw should be under 0.1A or 100mA.
Now check the the engine fuse block...
(The 80A / 100A fuse is bolted in.)
Pull the fuses one by one and measure current draw across the two points...
This should start your search.
Ignore anything lower than 0.1A (or 100mA) for now...
Find something that measures higher than that.
(Make sure nothing else is on in the car - i.e. dome light, door light, key off, etc.)
Trace the circuits one by one to see where it leads you.
Old 01-11-2014, 04:30 PM   #9
Pete_89T2
Pete_89T2's Avatar
I agree - get the FSM & wiring diagram and start tracing the circuit back from the turn signal indicator bulbs, and look for anyplace it could possibly short to, causing those lights to come on.
My best guess at this point is a bad CPU, probably a short caused by a failed solder joint. The CPU is where the electronic faggotry that causes both the turn signals and hazard flashers to flash happens... And since the hazard flashers operate with the engine off, it's a likely short circuit location. Try swapping in a known good CPU from another FC.
Old 01-11-2014, 05:33 PM   #10
Or quickie troubleshooting with the "CPU"...
Unplug the unit and see if the situation changes???
