| RX-8 (2004 - Present) All things to do with RX-8 |
Hard to say if they are using the computer to do the averaging or if it is true resistance that doing the work. It's been awhile since I read a cut sheet on level sensor. Most of the time the ones I work with are high or low level limit switches. Next week when I am bored I will read up on them.
#2 | |
The readings below. Fuel gauge reading Full 47ohm 3/4 210ohm 1/2 243ohm 1/4 326ohm Empty 326ohm So I'm guessing this is not gonna be accurate if rx8 somehow averages out from two senders? I noticed the reading of 326 never changed between below half and empty !!? Drove me crazy Maybe the two senders merge their wires parallel and cld be measured at that point? |
So today I followed the wiring back to cluster.
Turns out the two senders share the black/ brown trace and send the other two wires along with a single merged black/yellow-ish trace back to cluster. So a total of 3wires go directly to cluste from the two senders. I pulled the two plugs from a spare loom and twisted the unshared two wires (one from each sender) ( blue/red trace and white /green trace) together. Filled the tank and measured impedience basically as parallel from both senders and got 9ohms which I believe what is stated in the SM. ILL test at all the gauge increments to see if it seems consistent and post results. I don't think the ecu is making any calculations what so ever as the car I traced these wires to cluster had no ecu attached. |
Don Mega
good thread, should be more like this!
Damn it's weird!
So I cut out the fuel sender plugs n cable from an old loom to use as a test cable enabling me to read my running car and test in parallel, solo and in series to try figure this out. All seemed to be good till I hit half tank while testing both senders parallel Full 7-9ohm 3/4 55ohm 1/2 94 ohm 1/2 142 ohm left side only Not sure what to follow here seeing as the right side isn't gonna change now till empty. |
Now since it is a averaging sensor I wonder if it only takes input from certain OHM readings. So say anything above 90 OHM it only reads from one side vs the other.
Most of the sensor's I use are for temperature across a large area. Not a split sensor system like this. But trying to see the logic of what they are trying to read, then using a sensor to read it. I could see it doing something like that. |
#7 | |
The gauge cuts the circuit to the right sender once it gets below half. Much like how it activates the fuel light at near empty. Then only reads level from the left. My final readings were this Full 7-9 together 3/4 55 together 1/2 142 left side only 1/4 200 left only E 326 left only I'm still not convinced it's 100% accurate but I think it's close enough to program a new single sender |
