Old 12-17-2013, 07:17 PM   #13
jahjahsqc
jahjahsqc is on a distinguished road
Yes... walblows are the worst pump you can put into a rotary.... just throw that thing out and get a denso replacement pump and be happy....
As far as I can tell, and Ted agrees, there's two things to check here.... proper fuel pressure, and if the injectors are actually firing....
Also,..,.. I noticed that you said compression was 90psi..... how did you test this? If your tested it with a piston engine compressor without removing the Schrader valve... you could have 2 blown rotors and not know it....
Well, only the cylinder #1 injector is firing, injector bank 2 is not. Gonna swap an injector from the secondary row, but got tired of messing with it tonight.
Nope, I read on it before testing, pulled the schrader valve it bounced up to 90 psi. I figured that wasn't too bad for a motor thats sit for a year or more.
jahjahsqc is offline   Reply With Quote
