Old 12-14-2013, 04:37 PM   #11
I think i have modified the oem pedal assembly enough to work! Pedal ratio is 6.5 ish (rounded). The lower attachment point has a nut welded to the back since you can actually get a bolt through, the bolt will be bolt from inside the car going out with a nut outside since you can't get the bolt passed the reservoir inlet. I need to prime and paint the assembly and then work on the firewall stuff.
