Old 10-24-2013, 10:34 PM   #1
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
Injector Size advice
Ok, FC people! I need your guidance!!!
TL,DR:
S4 T2, 1/2 bridgeport (stock(ish?) small ports on center iron), Haltech Sprint RE ecu, BW S300 turbo)...
What injector sizes should i plan to run?
Longer version:
Most my rotary knowledge is FD based but I've picked up an FC (87 GXL body with S4 T2 swap) recently to enjoy and help relieve my FD from it's DD duty...
Well, the first day of owning the car I popped the engine and it's now rebuilt with a 1/2 bridgeport with stock (or nearly stock) small ports on the middle iron and BorgWarner S300 turbo... I plan to run at most 14.7 lbs but probably keep it around 10-12, based on the efficiency map of the turbo when I look it up... Ideally, I don't want to see more than 350 HP from the car, just want something to play with and enjoy and not have to worry about breaking any more plates...
Anyway, what size injectors should I run for my secondaries? would 950s be enough for the bridge and turbo? or should I play it safe and run 1600s? Computer is a Haltech Sprint RE. And are stock injectors 550s? or 440s?
Thanks for any help anyone gives...
Old 10-25-2013, 01:08 AM   #2
reese.leblanc
Doing my own thing
reese.leblanc is on a distinguished road
HopeStock TII injectors are 550s.
1600s should be plenty with an upgraded fuel pump. Personally, I would spring for a pair of the newer EV-14 style injectors. For one, you would know exactly what condition they are in. It's your choice to go with Injector Dynamics or the less expensive versions available through a number of vendors.
this helps!
reese.leblanc is offline   Reply With Quote
Old 10-25-2013, 05:40 AM   #3
Pete_89T2
Pete_89T2's Avatar
Stock T2 injectors are 550's (pri & sec), and I believe the N/A's are 460's, not 100% sure on those though.
Whatever size you need, I'd spring for the ID's as I've heard nothing but good reviews on those. Performance wise, the ID's are supposed to be very consistent, from minimal duty cycles to max.
Old 10-25-2013, 10:30 AM   #4
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
thanks for the info... i was thinking the stock were 550 but wasn't too sure... 2nd guessing myself and all..
anyway, i know one of you i could have called up directly and talked to about this... but this also puts more information on the forum for others to find in the future...
Old 10-25-2013, 10:37 AM   #5
omega
The new Sheriff in town..
omega's Avatar
omega is on a distinguished road
With the Haltech re I would run 1000cc primary's and 2000cc secondarys. Also you are going to need a good pump. I like the id injectors best. Its a lot of injectors but you can always tune down the injectors. I always over engineer my projects . Safety first!
omega is offline   Reply With Quote
Old 10-25-2013, 04:12 PM   #6
88turboii
destroy, rebuild, repeat
88turboii's Avatar
two ID2000's, no secondaries
