Old 09-25-2013, 10:32 AM   #1
infernosg
IT'S ALIVE!
infernosg's Avatar
Step 5: Rear Bearings, 5th, Reverse, and 4th Gears
All that's left is the gear and shaft assembly itself. The next step in the process is to remove the rear bearings and the 5th and reverse gear assembly allowing the mainshaft and countershafts to be removed, which then frees 4th gear.
Note: bearings may be with or without dust shields. My RX-7 had them on on both rear bearings but the Miata (shown above) doesn't despite being newer.
First remove the countershaft rear nut and bearing to get them out of the way of the mainshaft pieces. In order loosen the nut lock the transmission into both 1st and reverse by sliding the respective clutch hubs into position. This allows you to apply torque to the rear nut without the transmission spinning. The nut is staked so you will need drive that out with a punch or screwdriver. The nut is also installed with a lot or torque so clamp the assembly down and use a breaker bar. Once the nut is removed the bearing can be pulled off with a normal two- or three-jaw puller.
Next is the mainshaft rear bearing. First remove the c-clip.
Then the small spacer behind it.
This exposes two thick c-shaped washers held by a retaining ring. Remove these to get to the mainshaft rear bearing.
Assembly note: keep track of the spacer and c-shaped washers. They are specific thicknesses and are needed to set the clearance for the rear bearing (see FSM).
Here is where the first SST comes in. The actual Mazda SST is a bearing puller with very long arms. Since I don't have access to these SST's I had to get creative. Fortunately I stumbled across a fellow forum member who went through this same process and came up with his own SST: a modified, two-jaw puller:
Basically, it's a simple two-jaw puller with the normal arms replaced by long steel flatstock. I forget the actual length but I think somewhere around 17 inches was required. With this tool the bearing is removed exposing another set of c-washers and retaining ring and it allows access to the countershaft 5th gear companion.
The countershaft gear slips off easily revealing a long tube spacer.
Remove the tube spacer but leave the countershaft reverse gear in place as it's required to keep the assembly from spinning. Jump back to the mainshaft and remove the c-washers and retaining ring that were behind the bearing. This exposes a thick spacer.
Assembly note: as with before keep these c-washers and spacer straight as they're needed to set proper clearances.
The spacer slides right off but like the speedometer drive gear it also has a small steel ball underneath it.
Assembly note: keep track of that spacer!
Now 5th gear and its syncho can be removed. They should slide easily off the mainshaft. Be careful not to mar any surfaces especially the synchro!. If you removed the assembly from the vice like I did you'll need to get it back in there for the next step.
With 5th gear gone the notorious transmission rear nut is exposed. Here is where SST number two comes into play. The actual SST is a very deep-well 32 mm socket. Again, I don't have access to one so I got creative. The same forum member came to the rescue with a hacked and spliced 32 mm socket and tube.
This nut is held on with even more torque than the countershaft nut so expect to spend some time here.
Note: I had an even more difficult time torquing the nut during reassembly because the Miata reverse gear is helical. This meant every time I tried to torque the nut the countershaft reverse gear would try to walk its way out allowing the mainshaft to spin. The RX-7 reverse gear was straight cut so there was no forward or rearward forces trying to move the gear. I find it interesting not only is the reverse ratio different but the cut is as well.
With the nut off the 5th/reverse clutch hub is exposed. Using the same long-arm puller above lock onto the hub being careful not to damage the brass syncho on the other side and remove.
Note: during the disassembly process I found it easier to disassemble the clutch hub while it was on the mainshaft. This gave more surface area to grab with the puller. I will explain the disassembly of a clutch hub at the end.
Now the reverse gear and its syncho can be removed. Unlike 5th gear, reverse has a needle bearing and inner bearing race underneath it. Needle bearing:
Inner race:
Inner race removed:
Note: there is also likely a spacer between the reverse gear and the middle bearing. Remove this and keep track of it as it's needed to set clearance during reassembly (see FSM).
Next is the countershaft reverse companion gear. When trying to remove this gear I noticed the bearing plate cover interfered so I had to remove the cover. In order to remove the cover undo the bolts and pull it off. With the cover removed the countershaft reverse gear can be removed along with the idler gear and its two spacers.
Note: I don't believe the RX-7 FSM says the bearing plate cover has to come off. It's possible the different reverse ratio of the Miata makes this not possible where it is with the RX-7. Either way, don't forget to keep track of the spacers for the idler gear.
Now the mainshaft and countershaft can be separated from the bearing plate. Both have to move together to be removed. In my case the mainshaft separated easily but the countershaft didn't want to budge. I ended up having to use the puller to "pull" the bearing plate off the countershaft and even then the bearing was still stuck on the countershaft. Keep track of any spacer on the forward side of the bearing plate as it works with the previous rear spacer to set clearances. Be careful once the three are separated as 4th gear and its synchro are no longer supported and can simply fall off the mainshaft.
4th gear slides off the front of the mainshaft easily. Be sure its syncho and needle bearing come with it.
Exploded:
At this point the transmission has been reduced to this:
Note: there are lots of specific spacers and washers that are removed during this step. Keep track of them and their location for reassembly. If you are replacing parts (I did not) different thicknesses are offered to properly set bearing clearances.
Last edited by infernosg; 09-26-2013 at 10:16 AM. Reason: Corrected spelling errors, corrected syntax, elaborated some steps
Old 09-25-2013, 10:33 AM   #2
infernosg
IT'S ALIVE!
infernosg's Avatar
Step 6: Mainshaft and Forward Gear Assembly
The most daunting steps are done. From here it's a matter of sliding gears and clutch hubs off the mainshaft. Be careful handling the mainshaft to avoid dinging any surfaces and be mindful that 1st gear is no longer supported to the rear.
With 4th gear, its bearing, and synchro removed support the mainshaft assembly with the front pointing downward. Again, there will be a small spacer between 1st gear and the bearing plate. Remove this and note its location for reassembly.
Like reverse, 1st gear and its synchro are easily removed and are supported by a needle bearing and inner bearing race. Slide 1st gear and its synchro off the back of the mainshaft being careful not to ding any surfaces.
Needle bearing removed exposing inner race:
Remove the inner race and flip the mainshaft around to work on the forward side.
As with the 5th/reverse clutch hub pull the 3rd/4th hub off from the front of the mainshaft. Again, it's probably easier to pull the hub apart to avoid damaging anything. You can use a puller but I used a 1/8" piece of flat stock that I laid on the hub surface and tapped with a hammer, alternating sides. 3rd/4th clutch hub removed:
3rd gear is like 5th gear in that it spins around the mainshaft with no needle bearing support. Slide 3rd gear and its synchro off the front of the mainshaft and the forward side is complete. Flip the mainshaft around one more time to get to the 1st/2nd clutch hub.
Remove the 1st/2nd clutch hub using the modified puller or by lightly tapping on a piece of soft(er) metal with a hammer, alternating sides.
2nd gear is like 3rd and 5th in that it does not have a needle bearing and inner race. Slide 2nd gear and its synchro off the rear of the mainshaft and the mainshaft is completely disassembled.
Note: Sometime in the early-mid '90's Mazda added a second synchro to 2nd gear in the Type M transmissions. This is seen in the pictures above. This does not affect the disassembly process but means there are more parts.
This is basically the end of the disassembly process. Assembly is really the reverse but with clearance checks and torquing fasteners required. Be sure to inspect all bearing surfaces, synchro surfaces, gear teeth, clutch hub teeth, and other parts per the FSM prior to reassembly.
Assembly note: to reinstall clutch hubs and bearings I made my own driver out of steel pipe. I purchased two 1 ft sections of 2.5 in. pipe and cut the threads off the end of one. I also purchased a straight coupler so I could adjust the length between 12" and 24" and an end cap to use as a hammering surface.
Short version:
Long version:
The next section is pretty much optional. I'll go into detail regarding the disassembly of the bearing plate and clutch hubs.
Old 09-25-2013, 12:40 PM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
Step 7: Bearing Plate
If you intend to disassemble the bearing plate further (i.e. for center bearing replacement) and/or took apart one or more clutch hubs please read on.
Depending on your reverse gear your bearing plate is either still completely assembled or partly disassembled with the cover off. Completely assembled:
Partially disassembled:
Assuming your bearing plate is fully assembled start by removing the 6 bolts, noting two are different, to remove the cover.
Next, remove the idle gear and its two spacers. It's probably not required but I made note of which spacer was on each side and its orientation. Now the assembly looks like the second picture above. Again, you may already be at this step.
Note the main bearing can only be pushed out through one side. Support the bearing plate and use whatever method you prefer to drive it out.
The center countershaft bearing has a c-clip around it. The c-clip does not need to be removed to push out the bearing. Both bearings removed:
Bearings with c-clips and shims:
The shims fit between the bearing plate lip and the mainshaft center bearing and the c-clip and bearing plate for the countershaft bearing. Again, clearances (consult FSM). These can also be sharp so be careful. If you want to go further you can unbolt and remove the idler gear shaft but I did not do that.
If you took apart a clutch hub to remove it or are just curious about how they work work read on. All of the clutch hubs are basically the same with the only real difference being size.
Each clutch consists of a inner hub, which is fixed to the mainshaft, an outer locking ring, which serves to connect the hub with the drive gear, three keys to control the outer ring's movement, and two wire springs to hold the keys in place. To disassemble, if not done already, simple slide the outer ring off the inner hub making sure none of the keys or springs going flying off into space.
If you look at the ID of the hub you notice one side is chamfer and the other isn't. Pay attention to this when installing as the chamfers must point a certain way (check the FSM).
Assembly note: reassembling the clutch is fairly straightforward but there is a "right" way to do it. Place the keys in the outer grooves in the hub with the taller, center section pointing outward. You'll notice some of the teeth in the outer ring are missing a center section. Align these modified teeth with the keys and slide the outer ring over the hub. Lastly, install the wire spring by inserting the bent end into the hole and winding it around the hub. The wire must contact each key and must be "inside" the inward-pointing sections on the keys. It's a little tricky as one side often comes undone when you try to do the other.
That's pretty much it. I see this has already been made a sticky so that's a start. Feel free to ask any questions!
