Old 08-17-2013, 10:15 AM   #1
mystery
mystery is on a distinguished road
swap.
Alright from my previous issues as some of you know about ive been influenced to drop the 13b motor out of a 86-87 rx7 with turbo into my '85 12a, found a good setup on ebay thats going to basically got motor, tranny, cmp and all the attachments just trying to figure out what ill need to get far as the boltup to the rear end because from my research its not boltup without a plate anyone able to point me in the right direction?
mystery is offline   Reply With Quote
Old 08-17-2013, 10:42 AM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
MaxdaTrix can sell you a new driveshaft. Which you'll want anyway as the U-joints are not replaceable in most of the RX-7 driveshafts. The early model rear axles 79-83 had a different flange on the differential pinion than the 84-85 axles. I know the stock 85 shaft worked with my NA transmission. I'm unsure whether the TII splines are different than the NA at the transmission or not. If so they can probably put the proper yoke on the front for you. Best bet would be to give them a call and discuss what you want to do with them. You can't use the FC shaft as it is WAY too short.
Old 08-18-2013, 07:13 PM   #3
mystery
Excellent thanks for the advice frank im most certainlly going to be giving them a call this week and hopefully they can point me to what I need for this build!
