Old 07-22-2013, 05:55 PM   #16
BurntOrangeT2
No phonebook but OG calls
BurntOrangeT2's Avatar
BurntOrangeT2 is on a distinguished road
Weekend FIRESALE
MICROTECH ECU was $675 shipped, now $575 SHIPPED.
GUYS YOU CANT BUY A STADALONE ECU FOR THAT CHEAP ANYWHERE.
you get
ecu
harnesses
laptop dongle
laptop usb serial cable
Gabby Skern Tuned map good for 370 WHP with water injection and race plugs
Good until WED 10am
'89GXL - S4 T2 Swap, body work complete, time for paint.
BurntOrangeT2 is offline   Reply With Quote
Old 07-22-2013, 05:55 PM   #17
BurntOrangeT2
Spec Clutch
Racing Beat Plug Wires
S4 T2 Grey Rear carpet W/ Bins
Old 07-23-2013, 05:17 PM   #18
BurntOrangeT2
Microtech pending
Old 07-24-2013, 07:47 AM   #19
Silver86
now what?
Silver86's Avatar
Silver86 is on a distinguished road
I need a lot of these parts. Let me see what I can come up with.
1986 Rx7 coupe - arctic silver - sold
aka - 20bforme
Silver86 is offline   Reply With Quote
Old 07-24-2013, 03:38 PM   #20
Johnny_K
Johnny_K is on a distinguished road
I know the turbo has some slight shaft play and 15k miles on it but u think it still has a lot of life on it?
Johnny_K is offline   Reply With Quote
Old 07-24-2013, 04:01 PM   #21
BurntOrangeT2
Yeah i mean, what you see in the pictures is how it was when it put down 370 @ 17 psi. The shaft play, especially with a journal bearing is minimal. If I had a fresh BNR in my hands for comparison I'd be easy to tell how much. For the price, even if you had Bryan at BNR replace the CHRA it'd still be cheaper than having it done to ur stock turbo. The service is like $900...plus ur getting the blanket which is at least a $100 by itself.
You gotta figure, what's 15K miles off the life of a BRAND NEW turbo......extremely minimal
Old 07-25-2013, 06:01 PM   #22
BurntOrangeT2
> Microtech LT10S, includes laptop dongle, harnesses, all user manuals and wiring diagrams. Configured for stock FC coils, NO X4 BOX. - $675 shipped (PENDING)
> Authentic Greddy Type-R FMIC, sutup for water injection, needs new bov flange. INCLUDES matching Greddy BOV and all necessary T-BOLT clamps - $775 W/O Shipping
> Corksport Power Series Radiator, S5 fitment, modified for reverse duct hood, will work with stock hood, needs new bung for coolant level & temp sensor. Comes with matching Corksport upper and Lower Silicone Radiator Hoses, also includes custom E-Fan shroud and E-Fan - $215 W/O Shipping
> UIM, ceramic coated with all block off plates, includes throttle body, has throttle body mod and TPS sensor - $200 shipped
> LIM, ceramic coated, includes all block off plates - $150 Shipped
> S5 Turbo manifold, perfect condition, planed for a perfect fit on the engine and turbo side, ceramic coated - $125 shipped (PENDING)
> (2) RC Engineering 550's, 2K Miles, flow wonderfully - $150 shipped
> (2) Denso 680's, mileage unknown - $80 shipped
> (2) Bosch 1680's, about 10K Miles, - $200 shipped (injector cleaning from RC is $24 per if u want, still come out ahead of buying new)
> HKS Twin Power wired for FC use, takes 10 mins to install, great for race plugs, 17psi & 500cc of water injection - SOLD
> Corksport SS braided oil cooler lines, 10K miles - SOLD
> Complete, FC3SPro - type, parallel fuel rail setup, less than 4K miles. S4 rails, all SS braided line, Aeromotive A100 -6 FPR. Requires FPR to be mounted on firewall. You will need to clamp the end of the feed hose on your fuel filter, and clamp the end of the return on to the existing stock metal return line - $500 shipped
> SS 3" DP, fits any stock or BNR upgraded turbo, comes wrapped in DEI Titanium exhaust wrap, extra bung for o2 sensor and a bung for EGT sensor/gauge - $250 W/O shipping (PENDING)
> Series 5 BNR Stage 4 Turbo, 15K miles, slight shaft play and some compressor blade wear. Comes With DEI Titanium Turbo Blanket - $575 shipped (PENDING)
> BNR upgraded wastegate actuator - $100 shipped
> ACT 6 puck, sprung hub W/ HD pressure plate (Z65-HDG6), S4, great clutch disc life left, was replaced less than 200 miles ago - $300 shipped
> ACT Streetlite Flywheel, S4, will need a resurface - $215 shipped
> ACT rear counterweight, S4 - $120 shipped
> Spec Stage 1 Clutch, great disc life left - $225 shipped
> Racing Beat Ultra Ignition Wires - Race Version, 5000 miles - $80 shipped
> Racing Beat Aluminum Double Sheave, main pulley - $75 shipped
> Reman O'Reilly's FC Alternator with Racing Beat Double Sheave aluminum alt pulley, lifetime warranty - $100 shipped
- 1 S4 T2 turbo, no shaft play, small cracks in rear mani, great BNR candidate - $100 shipped
- 2 S5 Exhaust manis, ok condition - $50 shipped for one w/ all the turbo studs $40 for the one with 3 studs.
- 5x leading 2x trailing T2 coils - $30 each shipped
- 3x CAS sensors - $25 each shipped
- 1x S4 TII MAF Part # N318-13-210 - SOLD
- 1 pair of S5 fuel rails, great condition - $35 shipped
- 1 pair of S4 550 stock fuel injectors - $30 shipped - SOLD
- 2x '87 T2 ECU's - $45 each shipped - 1 SOLD, 1 LEFT
- 1 stock T2 top mount IC - $30 shipped
- 1 NEW S4 T2 LIM to block Gasket - $10 shipped
- 1 T2 4 port Pineapple Racing Medium Streetport porting template - $30 shipped
- 1 set NGK stock plug wires unknown mileage - $15 shipped
- 1 S4 Engine harness, only good for connectors if terminating a standalone. will sell - $5 shipped per connector or $20 shipped for entire harness
- 2x shifter surrounds, both plastic not rubber - $10 shipped
- 1 S5 shift knob, some wear - SOLD
- 1 logicon, worked when pulled, will need to crimp - $15 shipped
- 1 set of S4 turn signals - $15 shipped
- 1 set of S5 clear signals - $25 shipped SOLD
- 1 S5 drivers side electric mirror, great condition, needs paint - $35 sipped
- 1 T2 hood scoop insert, good condition, will need some reconditioning, all mounting points intact - $90 shipped
- 1 grey S4 T2 center console, no switch console, decent condition - $25 shipped
- 1 grey S4 T2 glove box, decent condition - $20 shipped
- 1 Complete Grey S4 T2 rear carpet w/ Bins - $75 shipped
- 1 set of Great condition S4 tails, No cracks or chips, color fading is apparent - $150 shipped (PENDING)
- 1 S5 drivers side tail light, decent size chips - $20 shipped
- 2x S5 passenger side tail lights, one has chips, the other is perfect - $30 shipped with the chips - $70 shipped without
Old 07-27-2013, 11:36 AM   #23
BurntOrangeT2
- 1 pair of S4 550 stock fuel injectors - SOLD
- 1 S5 passenger side tail light, has chips - $30 shipped
Old 07-27-2013, 11:58 AM   #24
BurntOrangeT2
Weekend Special - Air and Fuel
Good until Monday 10 AM
Email for fastest response: cdevers2011@gmail.com
> (2) RC Engineering 550's, 2K Miles, flow wonderfully - $150 shipped <-was, Now $110 Shipped
> (2) Denso 680's, mileage unknown - $80 shipped <- was, Now $60 Shipped
> (2) Bosch 1680's, about 10K Miles, - $200 shipped (injector cleaning from RC is $24 per if u want, still come out ahead of buying new) <- was, Now $165 Shipped
> Authentic Greddy Type-R FMIC, setup for water injection, needs new bov flange. INCLUDES matching Greddy BOV and all necessary UPGRADED T-BOLT clamps - $775 W/O Shipping <-was, now $675 SHIPPED.
> Complete, FC3SPro - type, parallel fuel rail setup, less than 4K miles. S4 rails, all SS braided line, Aeromotive A100 -6 FPR, includes matching Aeromotive Fuel pressure gauge not pictured. Requires FPR to be mounted on firewall. You will need to clamp the end of the feed hose on your fuel filter, and clamp the end of the return on to the existing stock metal return line - $500 shipped <- was, now $425 Shipped
Bundle the RC injectors, Bosch 1680's with the Parallel fuel setup get EVEN MORE MONEY OFF!!!!
Old 07-28-2013, 07:57 AM   #25
WankelsRevenge
WankelsRevenge's Avatar
Any chance you have a spare starter for a MT laying around?
Summary of this thread:
Old 07-28-2013, 08:19 AM   #26
BurntOrangeT2
Only one I got is the one I'm gonna use on my next build.
Sorry
Old 07-29-2013, 01:47 PM   #27
Gregory Casimir
how much would you ship the radiator without the fan to 33176?
Gregory Casimir is offline   Reply With Quote
Old 07-30-2013, 06:24 PM   #28
BurntOrangeT2
> Microtech LT10S, includes laptop dongle, harnesses, all user manuals and wiring diagrams. Configured for stock FC coils, NO X4 BOX. - SOLD
> Authentic Greddy Type-R FMIC, sutup for water injection, needs new bov flange. INCLUDES matching Greddy BOV and all necessary T-BOLT clamps - SOLD
> Corksport Power Series Radiator, S5 fitment, modified for reverse duct hood, will work with stock hood, needs new bung for coolant level & temp sensor. Comes with matching Corksport upper and Lower Silicone Radiator Hoses, also includes custom E-Fan shroud and E-Fan - SOLD
> UIM, ceramic coated with all block off plates, includes throttle body, has throttle body mod and TPS sensor - SOLD
> LIM, ceramic coated, includes all block off plates - SOLD
> Complete, FC3SPro - type, parallel fuel rail setup, less than 4K miles. S4 rails, all SS braided line, Aeromotive A100 -6 FPR. Requires FPR to be mounted on firewall. You will need to clamp the end of the feed hose on your fuel filter, and clamp the end of the return on to the existing stock metal return line - SOLD
> Racing Beat Ultra Ignition Wires - Race Version, 5000 miles - SOLD
- 1 T2 4 port Pineapple Racing Medium Streetport porting template - SOLD
- 1 set of S5 clear signals - SOLD
- 1 grey S4 T2 center console, no switch console, decent condition - SOLD
Old 08-03-2013, 05:10 PM   #29
BurntOrangeT2
Open to Reasonable Offers
Please Email for fastest response: cdevers2011@gmail.com
PayPal is: vickidevers@yahoo.com
Old 08-08-2013, 06:46 PM   #30
BurntOrangeT2
NEW PRICING!!
EVERYTHING MUST GO PEOPLE!!
> (2) RC Engineering 550's, 2K Miles, flow wonderfully - $150 shipped <- WAS, NOW $124 SHIPPED
> (2) Denso 680's, mileage unknown - $80 shipped <- WAS, NOW $64 SHIPPED
> (2) Bosch 1680's, about 10K Miles, - $200 shipped <- WAS, NOW $139 SHIPPED
> BNR upgraded wastegate actuator - $100 shipped <- WAS, NOW $79 SHIPPED
> ACT 6 puck, sprung hub W/ HD pressure plate (Z65-HDG6), S4, great clutch disc life left, was replaced less than 200 miles ago - $300 shipped <- WAS, NOW $239 SHIPPED
> ACT Streetlite Flywheel, S4, will need a resurface - $215 shipped <- WAS, NOW $189 SHIPPED
> ACT rear counterweight, S4 - $120 shipped <- WAS, NOW $99 SHIPPED
> Spec Stage 1 Clutch, great disc life left - $225 shipped <- WAS, NOW $189 SHIPPED
> Racing Beat Aluminum Double Sheave, main pulley - $75 shipped <- WAS, NOW $59 SHIPPED
> Reman O'Reilly's FC Alternator with Racing Beat Double Sheave aluminum alt pulley, lifetime warranty - $100 shipped <- WAS, NOW $84 SHIPPED
- 1 logicon, worked when pulled - $15 shipped
- 1 Complete Grey S4 T2 rear carpet w/ Bins - $75 shipped (PENDING)
