| RX-8 (2004 - Present) All things to do with RX-8 |
#1 | |||
Engines with carbs with leaky bowls would start better with this method, but it also increased wear&tear. The extra gas in the engine was a band-aid fix for leaking carb bowls that would normally be hard to start. The extra gas would also wash away IMPORTANT oil film that would normally aid in compression (starting) and decrease wear&tear from cold starts. No modern fuel injection engine should be doing this, and if there are problems on cold-starts, it is highly recommend to FIX the problem rather than apply this dangerous band-aid. -Ted |
#2 | |
rotary owner/driver.
#3 | |
| Tags |
| "stupid is expensive" |
