Old 06-09-2013, 12:56 PM   #1
Wish I could help you out with those questions...
Mines is an S4, and I haven't messed around with an S5 with the E-OMP to get enough info for you.
I vaguely remember the full-range TPS doesn't matter so long as it's linear...?
Old 06-09-2013, 02:04 PM   #2
JustJeff
JustJeff's Avatar
Yeah, it's linear...no drops in the range on either full or narrow. I've heard an osciliscope is a better test and if it's as easy as borrowing the tool and hooking it up I'll test it that way.
Originally Posted by yzf-r1
Old 06-09-2013, 04:59 PM   #3
Pete_89T2
Pete_89T2's Avatar
As long as it's linear, with no drop outs its should be fine. Referring to '89 FSM, page F2-81 cites a resistance measurement spec for the TPS, full & narrow ranges. To test, disconnect the TPS connector, and measure resistance across the TPS connector terminals it references at closed & wide open throttle conditions. Do this with the engine at operating temp OR you can use a screwdriver to lift the fast idle mechanism off the thermo-wax plunger so the TB is not sitting at a high idle for the closed throttle measurements.
Full range TPS @ wide open throttle should be 3.4 - 5.1 K-ohms; at closed throttle it should be 600~900 ohms. The narrow range is 0.8~1.2K ohms closed, and 4.0~6.0K ohms WOT.
