Old 05-02-2013, 12:15 AM   #1
willnordacgreen1211
willnordacgreen1211 is on a distinguished road
Corksport oil cooler line issues
Ok so like alot of 2nd gen rx7's my oil cooler lines were pretty leaky and needed replacing. after reading tons of good reviews I went with the corksport SS lines. the bottom line bolted up and fit just fine as it should. but the top line that goes to the back of the engine will not fit without twisting it at a 90 degree angle. this causes a huge kink in the line and Im afraid it will puncture it as well. the banjo fittings on the line are in line with each other but need to be mounted at a 90 so it can connect to the cooler and the engine. is this an issue only I am having? or is this just how they come? anyone have any pics of how they have their corksport lines installed? any help is appreciated as ive been fighting it all day.
willnordacgreen1211 is offline   Reply With Quote
Old 05-02-2013, 03:05 AM   #2
FC Zach
FC Zach's Avatar
Post up a pic, I'm curious how yours sits currently. I had no issue with my RB lines, I believe that my upper line had swivel 90s at both ends. I'd like to see what yours look like.
I'm guessing these lines are crimped solid and the banjos and are not designed to swivel? If that's the case, maybe you got a defective kit that wasn't assembled correctly?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 05-02-2013, 12:33 PM   #3
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
it will kink slightly but it isn't an issue but 90* is overkill, you should not need to be mounting the oil line so that it points directly towards the frame.
http://rotaryevolution.net
Old 05-02-2013, 04:43 PM   #4
willnordacgreen1211
I think I may have figured out the issue. The lines are mounted backwards. when I took the stock lines off the top oil cooler line was ran to the rear of the engine and the bottom line was routed to the front cover. not being rx7 savey I just assumed this is how they should go. gonne flip them tonight and they should line up fine... FML
Old 05-02-2013, 05:19 PM   #5
My5ABaby
My5ABaby's Avatar
Odd. I'm surprised they even reached that far. The top one is considerably shorter.
Community Service Manual
RotorWiki
Old 05-02-2013, 05:48 PM   #6
willnordacgreen1211
no they were switched on the oil cooler itself. so there was no difference in the distance of the mounting points. maybe like 1/2 inch or so but nothing really.
Old 05-02-2013, 07:24 PM   #7
Pete_89T2
Pete_89T2's Avatar
Yup, that's how they are made. FWIW, I had a similar installation problem with Corksport oil cooler lines. Fortunately Corksport replaced them for me without any hassle, and the replacement lines were fine. My issue was also with the longer of the 2 lines - it was made maybe 1/4~1/2 inch too short and the assembly alignment on one of the banjo fittings was off a few degrees. Was impossible to install on the cooler end without kinking it.
