rotaryevolution.net
Rep Power: 15 ![]() |
then you probably should not be attempting to do a weber install if you can't locate the brake booster or distributor. no offense but a weber is likely going to need to be tweaked to perform its best, and it sounds as if you aren't knowledgeable enough to do that.
http://rotaryevolution.net |
