Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotary Diagnostics Systems
Rotary Diagnostics Systems Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. www.rotarydiagnostics.com P.O. Box 524 Mont Alto. PA 17222 (717) 352-7096
Old 03-27-2013, 12:13 PM   #10
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
RotaryDiagnostics is on a distinguished road
$640 ... no thanks. And $225 for a software upgrade in sampling rate? Alrighty then Motec.
If the two rotor system was reasonably priced, I would have already purchased one.
You do not need the $640.00, 2-rotor system to acquire accurate compression readings on all compression faces of both rotors of a rotary engine. Our basic system allows you to test both rotors, just not simultaneously, and is priced at $355.00. Maximum sampling rate for that system is 240 samples per second which is more than adequate for determining accurate compression readings. Incidentally, the software upgrade is not required nor is it available for that system.
The other systems we offer are intended primarily for engine builders and rotary shops where a higher resolution sampling rate provides detailed analysis of the compression pulses and where the presentation format of the data to their customers may be critical. Of course, we sell those system to individuals as well.
There, now I feel better.
Larry Roberts
Rotary Diagnostic Systems
RotaryDiagnostics is offline   Reply With Quote
