Old 03-11-2013, 02:01 AM   #1
Kush47
Kush47 is on a distinguished road
Weird Knocking Noise 81 rx7
I got a 81 rx7 It making a weird knocking noise towards the back of the car, i don't kno if it the differential or drive shaft, etc.. I hav no idea wat it is, there is no visible problems. If anybody can help on some suggestions on wat the problem is it would be appreciated.
Kush47 is offline   Reply With Quote
Old 03-11-2013, 11:17 AM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Check your exhaust. Sometimes the hangers break and the pipe will knock against the bottom of the car when moving.
Old 03-11-2013, 04:25 PM   #3
mazpower
Rawr Bearclaw
mazpower's Avatar
Could also be a rear wheel bearing, it would be a cyclical noise.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
Old 04-11-2013, 01:50 PM   #4
ran83
ran83 is on a distinguished road
I had the same issue with my drive shaft hopefully that isnt the issue because the univesal joints are not changeable on the first gen. i had to buy a new drive shaft all together. good luck!!!
ran83 is offline   Reply With Quote
Old 04-11-2013, 01:57 PM   #5
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
jack up the rear end and run the car, it will be much simpler to locate where the knock is coming from. just be sure the car is secure on the stands. a car lift would be better but sometimes noises only appear when the suspension is loaded(ie exhaust rattling on the diff).
http://rotaryevolution.net
