#1 | |
1) Simple Green has been quietly decommissioned by the military, because they found out it actually eats aluminum - do a Google search, and you should find plenty on this. 2) Most metals (including steel, iron, and aluminum, etc.) are porous. Using a water-based cleaner (which Purple Power, PineSol, and anything detergent + water) will cause the cleaner to get into the metal. If it can get into the metal, it can get out of the metal. All those cleaners + grease or oils will cause a foamy mess. If you're going to use a degreaser where you're going to put back a lubricant like grease or oil, then use some kind of contact cleaner that will evaporate quickly. Brake cleaner would be ideal. In a pinch, you can use gasoline. Acetone is another option, but it'll eat anything plastic or paint! -Ted |
