Old 04-30-2008, 08:45 PM   #1
one320fc
one Apex @ a time
one320fc's Avatar
one320fc is on a distinguished road
Any one using REspeeds FC fuse brackets
While working on my engine bay I thought it would be nice to up grade from the fuseable links to the FC fuse panel, I have a spare so it wont be an issue there. Any one done this yet?
one320fc is offline   Reply With Quote
Old 05-08-2008, 03:02 PM   #2
bwaits
Talk - Action = Nothing
bwaits is on a distinguished road
Our part helps you mount the FC block. Once mounted you will need to do the wiring.
You will see a large white/red wire held onto the SA/FC block with a small screw, this wire needs to be fed into the supply for the FC block. You should see a flapper door on the side of the FC block with 6MM screws inside. This is where you put the white/red wire.
The rest of the wires in that same group are supply wires for various functions. You will need to add female spade terminals to the ends of the wires and then they will slide onto the male spade terminals on the bottom of the FC block. They are a fairly large spade terminal. You can find them at you local auto parts store for a few bucks a package.
Once complete you want to test that you are supplying the correct side of the FC block. Remove one of the fuses and see if it cuts the voltage to that function on the car. If it does not then you need to move the white/red wire to the other side of the FC block.
Hope that helps,
-billy
bwaits is offline   Reply With Quote
Old 05-08-2008, 07:37 PM   #3
one320fc
one Apex @ a time
one320fc's Avatar
Thanks Billy, Soon as I get my check from the IRS I will be ordering those brackets and Billet Machined One Piece Oil Pedestal
