FC gas pedal widening options?
Hey, all.
What are the latest options for widening the gas pedal? The way I sit in the FC, my right leg is bound up a bit by the wheel, and I can't swing my heel as easily for heel-toe. I'm looking for a decent option for widening the gas pedal. I found this initially: Autovation Technologies I'm not really looking to replace the whole set for grip or anything, though. Just the gas pedal, which that doesn't seem to widen that much. I was wondering if the NA/NB Miatas had the same gas pedal as the FCs? If so, I could use this: Flyin' Miata : Interior : Ergonomics : FM gas pedal extension And it'd be a more reversible install. |
Any number of (universal) pedal kits will work...
All of them should work. There really isn't such thing as model-specific. There are two basic types: 1) bolt-on, usually with screws / bolts and straps of metal 2) screw-on, drilled and screwed into your existing pedals Both types are basically "removable." I prefer Razo brand pedal kits. http://www.carmate-usa.com/html_razo...ort_pedals.htm -Ted |
#3 | |
From what I can tell, the FM cover and the Autovation set have the same slant and hole spacing. |
PPP-P-P-P-POWER!
http://www.srpracing.com/default.cfm
same as autovation, about $30 cheaper all options being equal (minus the titanium option as they don't do that) unless you've got a GOOD discount code.
1. Walk through a row of 22", or larger, rims 2. Say you love dubstep 3. ????? 4. PROFIT! Axiomatic: Total cacology. |
