Old 11-23-2012, 03:19 AM   #1
wanklefactory
wanklefactory is on a distinguished road
fuel pump relocation
hey guys does anyone know if i could just unplug the old pump take it out and relocate a new one in the engine bay and just wire it up to the ignition so it turns on when the key is on
wanklefactory is offline   Reply With Quote
Old 11-30-2012, 10:36 PM   #2
eprx7
eprx7 is on a distinguished road
I wouldn't put a fuel pump that far up stream in the fuel system. It would take quite some time to prime it also you are dealing with higher temps under the hood.
Why don't you just put it in the same location as the old fuel pump?
1979 SA F Prepared solo/ Track day car 12a w/Weber carb,RB header and exhaust,
Ground Control coilovers, camber/caster plates
GforceEng.panhard rod w/ tri-link,Panasports wheels w/Hoosier slicks.
eprx7 is offline   Reply With Quote
Old 12-17-2012, 06:49 PM   #3
Kentetsu
Kentetsu's Avatar
Be careful. Some pumps are designed to PUSH fuel, while others are designed to PULL fuel. Neither one will last long in the wrong application...
