Old 11-21-2012, 11:55 AM   #1
Pete_89T2
Pete_89T2's Avatar
Well here's a picture of the plugs. No evidence of wet oil anywhere when I pulled them. Probably hard to tell in these pictures, but color of deposits is a black to brownish and have a sooty texture to them - running my finger over them it feels like 1000 grit sandpaper, and some of the carbon residue transfers easily to my fingers. What do you guys think? Probably should pull the DP to take a peek at the turbo turbine wheel next.
Old 11-21-2012, 02:15 PM   #2
Spark plugs looks pretty good...
Blame is starting to shift toward the turbo turbine section.
Just to eliminate the easy stuff...
Stock turbo drain assembly?
If it's been replaced, what size fittings and hose?
Relocated drain point back into sump?
PCV system still intact?
Old 11-21-2012, 04:12 PM   #3
Pete_89T2
Pete_89T2's Avatar
That's what I thought about the plugs too, pretty normal wear & tear.
PCV is fully intact and verified to work per FSM procedure. I did have to modify the stock turbo drain to solve an interference problem with my RA OMP adapter. It uses -10 hose & fittings, retains the stock return point on the front cover and is routed almost the same as stock. Compared to stock, it takes a bit of an arc away from the block, but the plumbing has a downward slope the whole way back to the front cover. This thread has a photo of it, see post #6
http://www.rotarycarclub.com/rotary_...ad.php?t=14945
