| Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
#61 |
I got the laser cut parts back this week so I started work on the 2 link mounts.....
This is the CAD model. ![]() This is the mount for the chassis. ![]() These are the mounts to go on the diff housing. ![]() And here are they all are with a bit of a mockup.
RX4 coupe 20B conversion http://www.rotarycarclub.com/rotary_...ead.php?t=9884 |
#62 |
Can't wait to see the end product.
#63 |
Rep Power: 20 ![]() |
^Me too. Should be badass.
#64 |
I found a bit of time to get some welding done this morning.
Welded up the two link diff mounts. ![]() ![]() ...and the links themselves. ![]() Painted and fitted. ![]() ![]() When I am happy that I have finished with the diff I'm getting it powercoated.
#65 |
Ok a bit of an update!
Here's my latest investment... ![]() Tremec TKO 600 5 speed with Carbon Syncros, Brass fork pads and with an Ultimate Street short throw shifter, Quarter Master Hydraulic bearing, slip yoke for the tailshaft, a Direct Clutch twin plate, and a Green Brothers steel bell housing. ![]() I have to do a little mod to the box to suit the RX7 turbo starter and fabricate a gearbox cross member, I will detail this later.
#66 |
Brokeback Power!
im glad to see the project is still going strong. lovin it!!
#67 |
Had to make a mod to the TKO to clear the starter for Green Brothers bellhousing.
Some of this area has to be removed and a new hole drilled. ![]() Marked out the material to be removed and drilled new hole. ![]() Chopped! A bit un-nerving on a brand new gearbox ![]() ![]() Bellhousing back on.
#68 |
Just for interest, this is the difference between my old SV RX7 box and the TKO.
670mm Vs 730mm from belhousing face to shifter position. The RX7 box I had already done the shortened shifter housing mod.
#69 |
I put the TKO on the back of the 20B today and dropped them into the engine bay to measure up the gearbox cross member.
Sorry I don't have any pics at the moment as the missus is away and she took the camera and my phone is no better than a potato. The TKO fits the RX4 transmission tunnel very well and shouldn't need any "clearancing". I have measured up and modeled the gearbox cross member. ![]() Turns out to only need a very simple design .
#70 |
Here's the photos of the fit up...
![]() The shifter comes out pretty close to the factory hole. (Already butchered for the early RX7 box when I bought it ) The engine is 50mm further back than factory so normally would be spot on.![]() Good clearance around the firewall. ![]() Not bad around the trans tunnel either. As soon as I get the laser cut parts back I'll fab up the cross member.
#71 |
Still Building my FD
Rep Power: 17 ![]() |
Wow. This build is great! I really like how much fabrication you are doing on your own. And your rubber isolated transmission crossmember is great!
Uh.... hi. |
#72 |
I added some gussets to my CAD model just to stiffen things up.
![]() Got my laser cut parts back so welded it all together. ![]() ![]() Bolted in place. ![]() ![]() Checked the dump pipe for clearance as well. All looks sweet!
#73 |
Rep Power: 21 ![]() |
who are you using for laser cutting?
also, this bell housing is new to me. Is it a one off or a produced item?
#74 | |
The bell housing is made by Green Brothers Racing in New Zealand, www.greenbrothers.co.nz. They build in batches as they get orders. They make a Supra to Rotary steel bell housing as well as the TKO and some adaptor plates to use the Mazda cast bell housing.
#75 |
this might sound silly, but the TKO does not share the same pattern as a T-5 tremec correct?
| Tags |
| 20b, mazda rx-4 |
