Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Bubble Tech LLC
Bubble Tech LLC Bubble Tech- Rotary Apparel, novelty items and Car parts! Dayon, NJ Phone: 732-887-1025 www.BubbleTech.us
Old 11-12-2012, 11:24 PM   #7
muibubbles
Bubble Tech
muibubbles's Avatar
muibubbles is on a distinguished road
Muibubbles - This spacer goes between the case and the bottom cover, correct? I'm not 100% sure, but I think this part will also fit FC turbo trannys too. Reason I say that is according to Mazdatrix, the gasket part # is common between the FD's and FC T2's.
Yes, you are correct that it goes between the case and cover. I am not sure if they are FC compatible but I will look into it and find out! I may have a buddy with a spare FC tranny out just to double check.
Originally Posted by Garfinkles Motor Works View Post
What about what I did with my oil pan? Drill a hole between the bolts in the front and the bolt holes in the back .Drill to the size of the alum tubing that you plan to press into the holes .Weld the tubes in place,they should be at least 3/8 dia .Now the cool air will be flowing through the tubes cooling the hot oil .WOW an oil cooler with out any hoses to leak or a fan to burn up. My oil pan has been used for years with no leaks and it is not polished .
^^ that a pretty cool concept! i would love to see a pic of that!
Originally Posted by Jwteknix View Post
if it works for the tII ill pick one up
Awesome! I will look into it =)
Ps We are working on a 1" version which will most likely be the production one.
Capacity is roughly
.78 QT
25 oz
Bubble Tech
www.BubbleTech.us
muibubbles is offline   Reply With Quote
