| Piston Engine Conversion Have you replaced your rotary with a V8 or any other type of piston engine? Tell us about it! |
#13 |
Rep Power: 13 ![]() |
Some comparison pics are in order I think. Here's my buddy Josh's car with the "I don't give a shit about how it looks I just want to drift" approach.
![]() If you use a HEI distributor, you can expect to have to bash the firewall in. Perhaps you could bash it a bit better than this though. I won't be using a HEI distributor for this very reason. Also his windsheild wiper linkage is not capable of movement anymore I'll be using a standard diameter distributor.![]() What you can expect for clearance on thedriver's side. ![]() Passenger side clearance. ![]() Clearance around the starter area. ![]() This shot gives you an idea of the length of the engine. ![]() Same thing on the other side. ![]() So basically it fits fine, selecting components is important ahead of time. He pulled this whole thing out of a 3rd gen Camaro he had and just pretty much threw it in the car with the Granny's kit and called it a day. Utilizing the factory style mechanical fuel pump and all that sort of stuff. He doen't really have any issues after a couple small things were sorted out. has higher compression, bored over and all that junk. Whatever it makes more power than is necessary all the time. I'll be mid-mounting the alternator on the passenger side to lower the height and have a better fitting hood and fancy stuff like that. Also cause I'd like to use a factory carbon fiber hood if possible. I'll be spacing the rear of the hood up for added clearance for the air cleaner. Unless I go ahead and fuel inject it. Still contemplating that, as it will make the project take longer and cost far more. Decisions, decisions...... |
