Rep Power: 14 ![]() |
"stop" fuse
so my battery has been dying for a while now and i had enough charging so i went and got the battery and alternator checked, good.
Drain is at 1.2 amps on a 10 amp reading. so i started pulling fuses and it ended up being the "stop" fuse which is for brake lights and i dont know what else. But the brake lights arent always on and they do go on and off as i push the pedal in and out. When the fuse is out it shows 0.00 across, no idea what it is, need help cause i like people not crashing into the back of me lol |
I have Ultra power in me.
Rep Power: 15 ![]() |
What year is your car??
Here is a wiring diagram. http://foxed.ca/rx7manual/oldindex.html
It looks like the horn is also on the same fuse, if it is a S4. I wish I was more helpfull. try disconnecting the horn and see what the draw is. |
#4 | |
86 body with 88 t2 motor
Try pulling the Horn relay. I am not sure who disconnected the horn, but if it was stuck on something is still powering the relay that might be your problem.
The fan hit the shit!
Check for proper alt wiring also.
#7 | |
alright will do, but i dont think it goes off non stop and i wired it, it charges good, good alt too |
bump still need help :/
