Old 04-26-2013, 05:13 AM   #1
First of all, I gotta say congrads on this build!
Wish I could see it in person for myself...
Gotta love the link to the dumb club...
(Bent axle shaft? Are you for real?)
Only really useful info was the sheer pin reply.
Gotta narrow down the problem to either a resonance problem (which is sounds like) or a out-of-spec part (which would usually mean +speed = +noise, which doesn't sound like the case).
Let's concentrate on this as a resonance problem...
Do you know what your caster spec is?
Too little caster can cause your headaches.
Another more than 5-degrees should be okay - I would worry of caster is less than 5-degrees.
Since you basically did a front steering / suspension retrofit and others have complained about the same problem, I would tend to blame the retrofit itself as the problem...
Old 04-26-2013, 08:37 PM   #2
banzaitoyota
banzaitoyota is on a distinguished road
Beautiful car, glad I got to see it in person
My deuce
banzaitoyota is offline   Reply With Quote
Old 04-27-2013, 08:18 AM   #3
rwatson5651
RX-7 NUT
rwatson5651 is on a distinguished road
I dont know how I missed this build thread before, but I just read it front to back. I saw your car at DGRR as was, to say the least, very impressed!!!!
I dont WANT to like this car, but I just cant help it , Hell I dont like it , I LOVE it!!
I have never seen a piston conversion that I would give two cents for, until I saw yours!!!
I was so impressed that I nominated your car for the peoples choice award, that's alot for the rotorhead that i am. Peeps, get out and vote!!!!
Cool car, cool guy.......
2 cents
Robert Watson
rwatson5651 is offline   Reply With Quote
Old 04-27-2013, 12:28 PM   #4
85turbo12a
nerd
85turbo12a's Avatar
85turbo12a is on a distinguished road
2 cents
Robert Watson
thanks again man, it has a tendency to do that to the haters hehehe
i took it to a local gathering and got a few sideways looks, so i just popped the hood and walked away to talk to some ppl i knew, and i look back...20 ppl huddled around it...its impossible to hate
however it wouldnt be nearly as cool with a chevy/ford engine in it, even as clean as it is, it would probably be faster...like it needs more power...
but cool no...
85turbo12a is offline   Reply With Quote
Old 10-14-2013, 07:53 PM   #5
85turbo12a
nerd
85turbo12a's Avatar
wish i had something new to report....car runs fine, i only fiddle with the tuning because i can and i like fiddling...
some minor suspension mods coming soon, will post details during that project
going to make all attempts to make DGRR2014 and then some gearing up for a pikes peak excursion is in the works, long ride out there....
in the meantime a few pics of it out and about
https://scontent-b-mia.xx.fbcdn.net/...22121480_n.jpg
Old 10-14-2013, 09:52 PM   #6
estevan62274
counting down till DGRR
estevan62274 is on a distinguished road
Clean FB or whatever you call it now with that boinger in it
-74 RX-4
-84 REW GSL-SE
Past rides
-05 REW Swapped RX-8
-93 FD base
estevan62274 is offline   Reply With Quote
Old 10-15-2013, 02:51 PM   #7
85turbo12a
nerd
85turbo12a's Avatar
I have many names for it at times....most of them are NSFW...
hope to see you this year steven, there is some airport show in orlando coming up...might go irritate a few rotorheads at that one too...if i dont forget about it...
Old 10-15-2013, 07:05 PM   #8
estevan62274
^Awesome, hope you can make it to the meet.
I'm off that day so I should be going.
-74 RX-4
-84 REW GSL-SE
Past rides
-93 FD base
Old 11-27-2013, 12:07 AM   #9
85turbo12a
nerd
85turbo12a's Avatar
so i took it to the track a few weeks ago for the first time to get some data and see what it would do...well...first launch at 2k rpm....yeah the yoke available for the 7260 joint cant take it, nor did the greasable Ujoint, but that said the yoke failed badly, pics dont show it clearly, but the ears are twisted quite a bit, and the internal spline is twisted as well, that is the only thing available i know of for the T2 trans, unless i make one, which i lack the tooling to spline it...so i have a new shaft now, with a solid joint and ill just stick to the street until i can find something stronger, i beat on it relentlessly on the street with no problem, but with drag radials and VHT...bang...car only moved about 6inches....never did get a pass....dammit...driveshaft loop going in car ASAP....
Old 11-27-2013, 11:54 AM   #10
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
https://scontent-a-mia.xx.fbcdn.net/hphotos-ash3/q85/s720x720/1452447_10202503724105104_1928430939_n.jpg[/IMG]
[IMG]https://scontent-a-mia.xx.fbcdn.net/hphotos-ash3/q89/s720x720/1463654_10202503723665093_548634223_n.jpg
You are a sick. sick man. It looks like a beefed up T-5 or Tremec transmission is in your future. I don't think I've seen anything outside of a dedicated drag car twist off a yoke that bad. At least the rear end took it, ... this time.
Old 11-27-2013, 02:36 AM   #11
Monkman33
Still Building my FD
sounds like a driveshaft loop would be a very good idea.
I'm not into piston swaps... but this has me converted to an "Only liking amazingly well done piston swaps" enthusiast.
Uh.... hi.
Old 11-27-2013, 11:02 AM   #12
85turbo12a
nerd
85turbo12a's Avatar
thanks, I just try to do a good job on everything I do, within human and monetary limits..
yeah that has me spooked now, I am glad it wasnt moving then it dropped it, the car barely moved at all, the front end rose to the top of the struts than it popped, moved less than a foot.....glad it never did that on any of the "70" mph highway pulls
taking it to turkey rod run this weekend, should rustle a few jimmies in the very american muscle biased crowd
Old 11-28-2013, 11:42 AM   #13
85turbo12a
nerd
85turbo12a's Avatar
i have a 31 spline 8.8 with auburn, im not worried about it hehehe
yeah im already considering the expensive and time consuming project of a different transmission, even though the T2 has not failed, i cannot get a yoke for it that can take it, and if i do...then it might be next....the only trans i would consider would be the t56 or TKO600 with the high 5th gear OD, that way i can launch WOT and finally get my 30mpg highway
i was also considering the toyota r154 but those are starting to become rare these days
if i use a domestic trans i can get parts and beefy yokes for it
Old 12-09-2013, 10:23 PM   #14
85turbo12a
nerd
85turbo12a's Avatar
just a little take off video, was still on the old tires...spins a bit...those sucked so bad, they hardly even smoked, just spun like crazy
https://www.facebook.com/photo.php?v...17291682975858
