#29 |
Slow burn-rate or retarded ignition makes the shallow peaks to the right of the actual trace in this depiction.
The closer the peak is to 45 degrees the better. The area under the curve can also be increase by adding boost The Rotary is notoriously for its slow burn-rate. We must find methods to maximize it.
