Old 06-20-2012, 10:04 AM   #1
fc nut
member
fc nut is on a distinguished road
injector question
I have an 84 se. If I do a mild street port it,will the stock injectors and ecu be able to handle it? or do I need to go stand alone?
leaving my carbon footprint....one start up at a time
fc nut is offline   Reply With Quote
Old 06-20-2012, 05:52 PM   #2
mazpower
Rawr Bearclaw
mazpower's Avatar
I'd imagine you'd be fine with a mild street port. Best thing to do would be to put a wideband on it with the ported engine and see what the mixture is at. If its on the lean side you could probably get away with upping the fuel pressure a bit to compensate...although I can't see it being that lean.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
Old 06-20-2012, 07:22 PM   #3
fc nut
member
right now, my car has a s4 n/a engine in it and a coolant seal is blown. the original se engine that i removed can be rebuilt with just an o ring kit. i was thinking while i have it tore down,i might as well up the power a bit before i put it back together. i'm still not sure of what i'm doing yet,i'm just looking at my options.
