#61 |
Rep Power: 15 ![]() |
From tonight
All my fuel fittings ![]() Fuel pot mounted I going to mount the Bosch 044 above this ![]() And my rad is now piped ![]()
#62 |
Ok very productive day on the Rex
I've finished the fuel pot and the fitting of the bosh 044 and fuel filter. I've then twin lined upto the front rails ![]() Cable tie will be replaced Tuesday night with some nice Pclips ![]() And I've also managed to sort the rail with -6an fittings ![]() Onto the Intercooler fitting has gone ok most time was spent making up the ducting around the cooler ![]() ![]() ![]()
#63 |
A few from last night Vmount set up is now done
#64 |
Thought I would stick my BGW on I was going for a mad rear panel set up, which I'm putting on the back burner till I get my head around cad
#65 |
The finish line is near
![]() She started like a dream and sounds great, really different to what it used to sound like on twins I LIKE IT All I'm waiting on now is two 3" clamps for the elbow to bov tube Some photos ![]() ![]() ![]() ![]() ![]() And I need to iron the banner what better place ![]() ![]() ![]() The spec has ended like this for now Hurley stock port engine Garrett T04R 70/70AR V- Mount Fast acting air temp sensor TGS long runner manifold Turbosmart Hypergate 45mm running 10psi spring at the moment Turbosmart FPR1200 fuel reg Turbosmart Raceport BOV Turbosmart E-Boost Street Turbosmart Hoses 3.5" downpipe 3" downpipe back exhaust system by TGS Ported UIM 1ltr fuel pot rx7 std feed pump Bosch 044 main fuel pump twin fuel feed lines to the rails DM motorsports secondary fuel rail Primery rail tapped for -6 an Stock 550cc and new Bosch 1680 high res injectors Re-wired coils and pumps There is prob more which I will add
#66 |
Rep Power: 20 ![]() |
It's looking great man! Great work!
I also love the muffler on the WG dump tube. I wish I had room to do that on my tubes. |
#67 |
Well here we are front water seal has gone aroun the spark plug area
So I've pulled the engine ready for the rebuild and while I'm at that I'm going to give the bay a quick paint ![]() ![]() ![]()
#68 |
#69 |
Getting there slowly
#70 |
![]() ![]() ![]() ![]() Just a quick update
#71 |
Stone chipped the legs for extra protection
#72 |
Early start this morning for me was in at 5am spraying the engine bay before I started real work, it's been a long day but I'm very happy
Just starting now to get some bits back on her ![]() ![]() ![]() ![]()
#73 |
BIG THANKS TO JAMES
For helping me till 1200 on Friday night getting my engine stripped to see what we had inside. It took sometime today cleaning the rotors up ![]() ![]() ![]() ![]() We also found the engine was using 3mm seals I'm in the market for some 3mm conner seals, I'm guessing as I have a receipt from Hurley for the engine from the last owner that there his 3mm apex seals Has anyone used hurley conner seals with the 3 built in springs http://www.hurleyrotary.com/cornerseals.php |
#74 |
Great debate
![]() Well the engine bay is back together and the engine is cleaned painted and ready to go back togeather #can not wait to drive her again lol ![]() ![]()
#75 |
I hope to build the engine tomorrow night and have back running by next Friday
| Tags |
| fd3s, fduk, mwi, rx7, topgear stockport |
