| View Poll Results: What oiling setup to use for racing | |||
| Leave it stock and run the right engine oil |
0 | 0% |
| Leave it stock and add some pre-mix |
8 | 53.33% |
| Disable the metering pump and pre-mix |
6 | 40.00% |
| Other - I have posted a better idea |
1 | 6.67% |
| Voters: 15. You may not vote on this poll | |||
I'm not as familiar with the FB, but it should be in the same place as the FC. Look for it low on the engine's front cover, same side as the intake & exhaust manifolds. It will have some banjo fittings & tubing coming off of it that leads to the oil injectors. The FB will also have a mechnaical rod linkage that goes from the throttle body (GSL-SE model) or to the carb (all other non-FI model SA/FB's)
