Old 12-05-2011, 07:23 PM   #1
JustJeff
JustJeff's Avatar
If you're talking about the MIDDLE fitting on the front of the throttle body...
*This is normal.*
That fitting leads to PRE throttle body, so it will never see vacuum.
It will see boost when the turbo kicks in.
You will only see vacuum if you find a fitting POST throttle body.
The fittings either above or below both go to POST throttle body.
See above - you did nothing wrong.
That middle fitting is for the emissions system which leads to the purge valve.
It looks like you have everything routed right.
Mazda designed some complicated vacuum control system to suck out vapors from the "crankcase" to be pulled from two different areas of the oil filler pipe depending if the engine was in vacuum or under load with the turbo spooling.
I think it's kinda stupid, but Mazda spent a lot of money figuring all of this out.
As for the gunk on the backside of the throttle plates...
I think yours is a Kouki 13BT?
If so, this is more so...
This is due to reversion of the intake ports.
It's exhaust gases (and other junk) being blown up from the intake ports from inside the engine and emissions.
On Kouki 13BT engines, the secondary ports open up first prior to the primary ports.
This fact allows stuff to blow back up the intact tract and tends to coat the insides of the intake manifolds and backside of the throttle plates.
Again, it's normal.
I'll have to get more detailed info about how I have my vacuum hoses routed. Tomorrow night if I get out of work with enough time to make progress I'll go work on my car. At that time I'll get more detailed info and pics.
What I remember by memory is this:
Front 3 nipples on the UIM
  1. Top = capped off and not used
  2. Middle = goes to the purge control valve
  3. Bottom = comes from the purge control valve
Rear 3 nipples on the UIM
  1. Top = Boost gauge (right now it's connected directly to the mechanical gauge. Normally I have it routed to the electric sender for the Greddy boost gauge.
  2. Middle = IIRC is the larger and goes to the OMP injectors via the splitter. One of my nipples on that splitter broke. I have it plugged and get vacuum/pressure (not sure which) from a different source on either the UIM or LIM. But only for that one OMP injector.
  3. Bottom = Not sure I'd have to see it to know, it is definitely not capped.
For the OEM BOV and pressure sensor I route that from the nipple on the UIM near the BAC...with a splitter of course.
I'll get more detailed info in the next day or so.
Originally Posted by yzf-r1
Old 12-06-2011, 08:44 AM   #2
Pete_89T2
Pete_89T2's Avatar
  1. Middle = IIRC is the larger and goes to the OMP injectors via the splitter. One of my nipples on that splitter broke. I have it plugged and get vacuum/pressure (not sure which) from a different source on either the UIM or LIM. But only for that one OMP injector.
On that larger middle nipple, you're correct that it is supposed to go to the 1-4 splitter, and from there to each OMP injector. If memory serves, that nipple is not vacuum, it's just an air bleed (pre-throttle plates). If the splitter is broke, just get yourself 3 "Y" or "T" style vacuum line fittings and use them to make a functional 1-4 splitter, and connect to each OMP injector. If that one OMP injector you have plumbed solo is getting vacuum instead of pre-throttle air, it may not work properly.
Old 12-06-2011, 03:09 PM   #3
JustJeff
JustJeff's Avatar
Good to know. I wondered about that and I've kept an eye on the OMP hoses. I rebuilt them with clear teflon hoses and they all have oil traveling through them. When assembling the engine I thought about getting a splitter like you suggested, but I assumed all the nipples on the intakes saw the same pressure and/or vacuum. Apparently I assumed incorrectly and need to do some more reading about emmissions removal and such.
What the OCD person in me wanted to do was to remove the spiders nest entirely and get some metal hoses to connect what I was keeping. I really didn't like the idea of having to track each hose from it's source and risk mistakes on routing them. I may go back to that idea. Get some metal hoses and bend them to route underneath the UIM and TB.
The top rear nipple on the UIM is what I used to route to my boost gauge. The mechanical sees no vacuum. As a side note this might be related. My brakes have been "mushy" since the rebuild. Before it they were good. I've assumed this whole time that either I didn't get all the air out of the lines or that my master cylinder coincedentally went out. Is it possible that I've got a vacuum/pressure issue that is also causing problems with my brake booster? I have the brake booster routed as it normally is. The metal fitting on the LIM to the metal hose on the firewall.
